1990 Steering Replacement
Old Dec 3, 2011 | 05:44 PM
grantar2's Avatar
grantar2
Default 1990 Steering Replacement
Team, for whatever reason the Chevy guys used some unqiue parts in the 1990 Corvette Steering column. The question is can a 1991-96 column be used to replace the 1990 column. Internal parts for the 92-96 seem to be much more available. Anyone have experience doing this? Is the later conversion from OBDI to OBDII an issue?
Old Dec 3, 2011 | 08:20 PM
VetteMed's Avatar
VetteMed
I just swapped a 1990 column into my 1991. The 1990 column is slightly shorter in the part that is in the engine compartment, and the airbag wiring is different. I have the 1990 airbag wiring and clockspring if you need it.
Old Dec 3, 2011 | 11:20 PM
grantar2's Avatar
grantar2
Thanks for the offer, Did you have any problems getting it to fit despite the slight difference?
Old Dec 4, 2011 | 02:00 PM
VetteMed's Avatar
VetteMed
No, it seems to work fine, I've driven a few hundred miles since then.
To 1990 Steering Replacement
