Any recommendation for shocks?
Old Dec 3, 2011 | 08:32 PM
Mustang_Eater's Avatar
Mustang_Eater
Default Any recommendation for shocks?
I am going to replace all the shocks on my 1989 Coupe.
Does anyone have any recommendation for shocks? I don't want to go with just average shocks. Right now the ride gets very bounce when I'm going at higher speeds and go over a bump.....
Old Dec 3, 2011 | 08:42 PM
Marv02's Avatar
Marv02
Koni Reds.
They are adjustable.
Old Dec 3, 2011 | 08:49 PM
leesvet's Avatar
leesvet
Originally Posted by Marv02
Koni Reds.
Can they be adjusted on the car? All 4?
how much? similar to Bilsteins??? more or less? 'Steins are the standard and cost about $75-$100 each.
Old Dec 3, 2011 | 08:57 PM
Marv02's Avatar
Marv02
The only Draw back about adjusting Koni's you have remove them from the car to adjust them.
I have mine in the middle setting so far I like them i had them on the car for a year now.
They cost about the same as Bilsteins.
QA1 you can adjust them on the car but they cost more cash.
Old Dec 3, 2011 | 09:06 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Whats your budget?
I ask because you may want Koni and QA1 but, they are expensive. Id say stick with Bilsteins if your Vette is a driver.
The QA1 single and double adjuster ****(s) can be adjusted while mounted on the car.
Old Dec 4, 2011 | 03:33 PM
mako41's Avatar
mako41
Originally Posted by PLRX
Whats your budget?
Is that a pic of a coilover setup? If so what setup are you running?
Van Steele?
If it's not a coilover QA1 dual adjustable setup do you have part #'s for those shocks to be used with the OEM leafsprings?
Old Dec 4, 2011 | 04:07 PM
PLRX's Avatar
PLRX
2017 C4 of Year
It is the Van Steel QA1 set up. I dont k now the QA1 part number but, I bet Google will
help you tremendously.
You can call Paul at Van Steel tomorrow, I bet he sells a QA1 shock set up for C4s.
Old Dec 4, 2011 | 04:16 PM
mako41's Avatar
mako41
Can you post some more pics of your setup.
How did you mount the front swaybar with the Van Steel setup, I understand it needs to be moved to clear the coilovers.
What coil spring rates are you running?
Do you autocross or race your car?
Old Dec 4, 2011 | 06:18 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Do a search on my profile and you will find all information you need. There are three threads on that project. The sway bar was moved forward 5/8".
I have not taken The Ghost to the drag yet but, I do drive the crap out of it and participate
on other spirited runs, solo runs and Bomber Runs. Currently, Im working on it because I had a curve on my way home.
The coilovers are a great improvement over the monospring set up...they are amazing I can
only imagine what a set of Penskes or Pdaft would do to a C6 Z06
I have to learn to turn the damn ASR off everytime I go for a drive.
Old Dec 4, 2011 | 08:54 PM
Rich B.'s Avatar
Rich B.
I went with aftermarket Bilsteins on my 86 ragtop...Affordable and the ride is firm but comfortable...
Old Dec 5, 2011 | 07:41 AM
1963SS's Avatar
1963SS
I replaced my KYB's with Bilsteins and have been very glad I did. IMO the Bilsteins are all you would need for 99.4% of your driving needs. The dampning seems to be perfect for a great street ride and for $380 or so they're hard to beat.
Old Dec 5, 2011 | 08:17 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I'm not looking for coil overs but am looking for an adjustable for the weekend autox's.
To Any recommendation for shocks?
