Heat and Headers?
Old May 8, 2002 | 11:50 AM
AlHale's Avatar
AlHale
Default Heat and Headers?
Have a 1994 LPE with SS shorty headers. It seems the heat in the engine compartment is extreme to the point of melting the plastic wiring loom on the passenger side. Any one else have this problem with heat? 180* therm and the fans working as normal but just seems that too much raidated heat from the headers. Should I wrap them?
Old May 8, 2002 | 11:52 AM
scorp508's Avatar
scorp508
Default Re: Heat and Headers? (AlHale)
Are the headers ceramic coated? I just installed one of my new hooker headers yesterday. After seeing how close some things come to them, I plan on buying some heat wrap and wrapping the OTHER stuff. I don't want to wrap the headers because this supposedly will cause the coating to fail prematurely.
Old May 8, 2002 | 12:00 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Heat and Headers? (scorp508)
If uncoated a heat wrap may be necessary.
Scorp, I don't think you'll have problems with that HPC coating inside & out. It realy does a great job of getting the heat out the back. I'm running HPC coated TES on the IROC for years and it's even cooler than stock. One of my MSD plug wires is about 1/8-1/4" from a header tube and not a hint of a problem.
Old May 8, 2002 | 12:11 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
I agree with Scorp. I have ceramic headers and have wrapped my starter, fuel and brake lines in places where they come close to the headers...
Old May 8, 2002 | 12:35 PM
vader86's Avatar
vader86
al, yours sounds like they arent coated or the coating has worn off, you can have them sent to Jet Hot and recoated, or wrap them up. Would be a good idea to wrap up your starter while youre at it
Old May 8, 2002 | 12:46 PM
black bart's Avatar
black bart
Default Re: Heat and Headers? (vader86)
I have TPIS coated headers and they have been wrapped for about three years with no problems the coating is still good just a lot cooler when wrapped.
Old May 10, 2002 | 12:24 AM
AlHale's Avatar
AlHale
Anyone have a set of Shorty headers coated? How much is a good price?
Old May 10, 2002 | 01:24 AM
vader86's Avatar
vader86
Have them coated at Jet Hot http://www.jet-hot.com
To Heat and Headers?
