Hitting the limiter
Old May 8, 2002 | 01:15 PM
97Supra's Avatar
97Supra
Default Hitting the limiter
After changing the driver's side header gasket the other day I noticed the car now hit's the limiter pretty hard on the 2-3 shift (it'll bang the limiter 5-10 times before it shifts, which is bad considering it's a gas cut limiter right?), and slightly on the 1-2 shift. The cable that goes from the throttle body to the asr came out of adjustment when I moved the unit to access the headers.....so I'm assuming that's what's causing the problem. Can anyone tell me how to put that cable back into proper position?
thx,
Jason
