L98 Rebuild?
Old May 8, 2002 | 03:09 PM
gpagaduan's Avatar
gpagaduan
Default L98 Rebuild?
OH MAN!!! Ok, here is what happened. Car made a loud noise yesterday morning on the first crank. I took a look and everything looked ok and then it started right up. Had some white smoke coming out of the exhaust but didn't think anything of it because it was a cold morning. On the way to work my coolant light came on. My temperature was fine and I pulled over to check for leaks but didn't find anything noticeable. Since I was only three miles away from work, I continued on. At lunch, the car wouldn't crank..did the same thing as in the morning.."ka chung..ka chung". Tried a little later in the afternoon and got it to turn over but a lot of white smoke came out of the exhaust. I ran the car for about five minutes to see if it would go away and it didn't. A co-worker convinced me not to drive it and bring it to her mechanic of 9 years. This morning I got the news...He said the piston or pistons froze. Needs a rebuild or a new engine. Having it towed back to my house to ponder my 1990's fate.
Old May 8, 2002 | 03:14 PM
Black87c4's Avatar
Black87c4
Default Re: L98 Rebuild? (gpagaduan)
Don't see how the pistons froze when it was running, sounds like blown head gasket.
Old May 8, 2002 | 03:23 PM
scorp508's Avatar
scorp508
Ouch, sorry to hear that. A $3500 ZZ4 crate engine might be the best route.
Old May 8, 2002 | 03:25 PM
gpagaduan's Avatar
gpagaduan
Default Re: L98 Rebuild? (Black87c4)
I agree, but it won't start...kinda like the start engages but can't crank. I think if he kept trying he could get it to turn over. We'll see...I'm going to get a second opinion from my Uncle. This can turn out to be an opportunity to learn more mechanics stuff...or this can turn out to be a big PITA!!
Old May 8, 2002 | 03:34 PM
Black87c4's Avatar
Black87c4
If it will turn over at all they are not froze but would think there's some damage there, sorry to hear about that. If the cylinders aren't too bad and no cracks anywhere a rebuild might be in order. Looks like a 355 or 383 is in your future, that might not be a bad thing.
Old May 8, 2002 | 04:10 PM
GlockLT4's Avatar
GlockLT4
Head gasket. If you can turn the engine over by hand.. it's not a frozen piston... unless the rod snapped with it.
383 time! :cheers:
Old May 8, 2002 | 04:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When you get it home pull all the spark plugs and try to crank it with the starter. Maybe hydrolock if lots of water in there.
If it cranks get a tester at Sears and run a compression test to see what's up.
[Modified by 65Z01, 2:18 PM 5/8/2002]
Old May 8, 2002 | 04:30 PM
WINNER's Avatar
WINNER
Default Re: L98 Rebuild? (65Z01)
[QUOTE]When you get it home pull all the spark plugs and try to crank it with the starter. Maybe hydrolock if lots of water in there.
Old May 8, 2002 | 04:53 PM
MrJay's Avatar
MrJay
65Z01 is right after you get home take out all the plugs and see if it turns over then and if it does check if you are getting any water out of the plug hole and I would check your oil and see if you have any water in it.
Dont run it to much more until you make sure it has water in it because if some of the water is gone then maybe the temp sending unit is not in any water to see how hot your engine really is.
Jay
Old May 8, 2002 | 05:29 PM
gpagaduan's Avatar
gpagaduan
Default Re: L98 Rebuild? (Glock'94)
Glock, what do you mean by turning the engine over by hand? Sorry, I'm still learning.
Old May 8, 2002 | 06:20 PM
GlockLT4's Avatar
GlockLT4
Get a breaker bar and attach it to one of your pulley's (A/C is the easiest on an LT1). Turn it. If your damper turns (which means your crank and pistons are turning), that means that your pistons aren't "frozen". The only way that this wouldn't be true is if you've broken a rod. (or a wrist pin or something that would let the piston stay frozen in there.
GlockLT4's Avatar
GlockLT4
Default Re: L98 Rebuild? (WINNER)
Hey.. good point! If all your coolant is in there, it's trying to compress water instead of air, and we all know water isn't compressable ... pretty much at ALL.
Old May 8, 2002 | 06:25 PM
BBA's Avatar
BBA
Had the same thing happen to my 79...turned out one of the pistons disentegrated.
Since the C4 has hypereutectic pistons, it is possible the top popped off of one of the pistons.
Old May 8, 2002 | 06:26 PM
gpagaduan's Avatar
gpagaduan
Will the engine start with a broken rod...and if so, what kind of (additional)damage is going on? I saw Summit's engine kit,page 18 in the March-April catalog. Is that what I need for a rebuild? Does anything need to be machined? How do you visually check for damage? Does the whole thing need to be hoisted out to inspect for a damaged block? Thanks for all the responses guys!!
Old May 8, 2002 | 06:31 PM
GlockLT4's Avatar
GlockLT4
Sure it'll run with a broken rod.. but not well. With a broken rod I'll bet your piston would be pushed up so high the valves would be hitting it though.. and that would = one destroyed engine. And it will be way out of balance. Oh, and with a broken rod (if it's still attached to the crank).. you're going to throw it out the side of your block very quickly. I wouldn't try to start it.
Why exactly does your engine guy think it's frozen? How did he come to that conclusion? I have never heard of anyone having that happen on here before.
[Modified by Glock'94, 4:39 PM 5/8/2002]
Old May 8, 2002 | 07:00 PM
Dryseals's Avatar
Dryseals
I agree, head gasket, pull the plugs and see what you got. If it is the head gasket and depending on the milage you may be able to salvage the motor or at least get a few more years out, IF you get the coolant out of the cylinders in time before they decide to cause some rust. If you are afraid of pulling the heads then take it to a mechanic. If you have know fear of pulling the heads, get a book and a video camera. Video everything under the hood and as you remove each component stop and video it. When you go to put it back together its very helpful.
Old May 8, 2002 | 07:04 PM
GlockLT4's Avatar
GlockLT4
Default Re: L98 Rebuild? (Dryseals)
YES! I take lots of pictures for that very reason.. and they have come in VERY handy!
To L98 Rebuild?
Old May 8, 2002 | 09:26 PM
corvette1990's Avatar
corvette1990
Yes I would agree with the group that it is a bad head gasket, just like mine was. The antifreeeze will run out of your back cylinders I bet!!!. When you pull the heads off, you will see that the back of the head gaskets near the firewall will be almost gone. That is where the 350 heats the most and breaks down the head gasket. Wish I could send my pics of my blown head gasket. The rear cylinder would indeed fill with water and make it hard to start, towards the end, the car once almost started the reversed direction as the water was uncompressible. I had good rings though, as none ever got down into the oil. I went the ZZ4 route. The estimate to rebuild a questionable block that mayb be cracked and have heads worked, and new bearings and cam almost cost as much as the new zz4 motor in my DC area. goodluck.....
Chris
Old May 8, 2002 | 11:09 PM
gtsyellow's Avatar
gtsyellow
Default Re: L98 Rebuild? (corvette1990)
another smog legal option besides a zz4 that's very simple to assemble is just finding a rolller block, scat crank $250, eagle rods $220, speed pro forged pistons $300 or KB, GM or speed pro hyper if you aren't going too nuts for less even. speed pro hypers are 150 on ebay. good engine shop, something like a zz9 cam or the lt1 version comp cams, they have a few different models. edelbrock centerbolt heads will outflow the zz4 head by a good 20cfm or more along with retaining a 170cc runner. a combo like that all said and done should run about 3500 and make a good 30-40hp+ over a zz4 with a decent large tube & big mouth base.
Old May 8, 2002 | 11:45 PM
jimbos86vette's Avatar
jimbos86vette
Default Re: L98 Rebuild? (gtsyellow)
I agree, pull plugs, crank engine, I'll bet you get anti-freeze coming out the spark plug hole... blown head gasket.
