Coolant leak at head?
Old Dec 7, 2011 | 09:27 PM
salome10's Avatar
salome10
Default Coolant leak at head?
94 Coupe with 175000 miles. Seems to be leaking coolant out behind the passenger side head. (hard to see) Is there a freeze plug there or could it be a head gasket. Doesn't use any oil and still runs like a striped *** ape.
Have to add coolant about every 3 weeks. I assume if it is more than a gasket and I have to do anything to the heads it will be time to do the whole engine. Can anyone recommend any good shops in the So Cal Inland Empire area?
Old Dec 8, 2011 | 12:58 AM
BacknBlack's Avatar
BacknBlack
It sounds like the coolant crossover tube. There are two washers per end with rubber inserts that seal it. I would check there first. But they are not cheap. $12.00 per washer.
http://www.summitracing.com/parts/NAL-10108689
Old Dec 8, 2011 | 10:47 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Not unusual for head gasket to leak from the rear of the head. Get an extendable mirror to see for sure.
Old Dec 9, 2011 | 05:24 PM
salome10's Avatar
salome10
Default coolant leak
Pulled the heads and found a tear on the one gasket. Everything else looks great. My question now is should I have the heads milled before i put her back together? I just don't want to do a half *** job and create further problems that would require taking everything else apart again or lead to having to do the entire engine. No carbon build up at all on the valves bore looks clean and smooth as can be. If I am not going to have to mill the heads what would you recommend to use to clean them up some to get a good seat on the gasket?
Old Dec 10, 2011 | 03:28 AM
Cliff Harris's Avatar
Cliff Harris
The heads only need to be milled if they are warped. A machine shop can check for flatness.
I scraped the gasket surfaces down to bare metal with a putty knife. Funny thing is that I accidentally broke it off to a stub about 1" long and now the sharp edges work better than before. There's some stuff called Permatex Gasket Remover #80646 that somebody recommended for removing the carbon from the tops of the pistons. Works pretty good on gaskets too.
Old Dec 10, 2011 | 10:28 AM
STL94LT1's Avatar
STL94LT1
Just take the heads to your local machine shop and have them resurfaced, no need for milling.
Old Dec 13, 2011 | 11:49 AM
salome10's Avatar
salome10
Thanks for the input. Sent both heads out to be resurfaced and pressure checked should have them back today. Am I going to have to do any adjustment on the valves?
Old Dec 13, 2011 | 02:57 PM
desertmike1's Avatar
desertmike1
have the machine shop check your valve, and guide wear, and replace the oil seals at a minimum.
Old Dec 13, 2011 | 05:21 PM
STL94LT1's Avatar
STL94LT1
Yes, when you reinstall the heads the valves will need to be adjusted.
To Coolant leak at head?
