Im just curios, what is the best replace engine for C4 L98? ZZ4 crate engine? And can you use the bosch injections system on a zz4 crate? Or MUST you go carb?
Re: What is the best replace engine for a C4? (devilfish)
yes the ZZ4 short block is what we use for it, you could just remove the carb that comes with the crate and instal the TPI, its supposed to be a direct fit.
I don't believe the ZZ4 will bolt up to the TPI. You'd have to get either a special intake manifold, or just get the ZZ4 short block and add your own heads.
