The other day going home one of my Co-works was behind me and he told me when I got on gas he said there was Black smoke as I pulled away from him.
I have a 383 with LT4 hotcam PCMforless tune.
The car is tuned for my set up but is this normal I was concern I could been running to lean at first due to the 24# injectors but now It seems it run Fat when you put your foot in to it.
I guess I need to find a shop around me that I can trust to put on the dyno and fine tune the car yep More money and the problem to find a shop to do this with out breaking the bank doing so.
Or, you can do what you contracted with PCMforless to do.
He takes a guess at your tune, you provide datalogs. Alvin re-tunes.
Process is repeated (at zero cost to you), until tune is spot on.
I am old school 2 stroke carb dirtbike racer, guy I understand how to get a 2 stokes to run spot on and get it to scream in my sleep carbs I know how to make them work.
But this TPI stuff is still a new to me thats why I had PCMForless do the tune.
What is a Datalog where do I get a Datamaster.
I like the Idea of PCMforless do a retune with out costing me more money but like I said where do I get a datalog done or can I do it my self.
Originally Posted by James93LT1
Datalog with "Datamaster" and e mail the results to PCM for less.
He will fine tune your tune.
For WOT you will need a Dyno or be able to datalog with a wideband.
On anouther forum someone had a good point I dont know what temp the motor was at it could not been up to temp yet that could of let the motor run fat when I got on it.
Lean can be a very bad thing I going to pull the pulgs and due a plug readings and as long as they are out I will due a Compression reading also the motor has about 6000 miles on it now so it broken in now.
Originally Posted by weaselbeak
I think mail order tuners err on the side of too rich as it's less of a problem than too lean.
Marv, it's not just a wideband 02 sensor but a display as well. I have a LM-1 which datalogs for 20 minutes plus gives a realtime display. For me it has been invaluable. Here it is on the lower left. Willie
Next qustion will the wideband pass Ca snog you know how much fun this can be to deal with.
I started t look at prices from Mid $100's on up which one it a street car.
QUOTE=383vett;1579496838]Marv, it's not just a wideband 02 sensor but a display as well. I have a LM-1 which datalogs for 20 minutes plus gives a realtime display. For me it has been invaluable. Here it is on the lower left. Willie
The wideband is just a tuning tool. It doesn't tune for you and has nothing to do with emissions. It simply tells you what the afr is at all times. You will need to install another bung in the exhaust and run the wideband 02 sensor in addition to your stock 02 sensor.
OKay the header on the right side has a Bulge thats not being use as of now.
Well beening in Ca it time to get the car smoged I woundering will pass knowing it blows rich at WOT.
At normal cruise It seems to run clean.
So I started to look around for someone that can put the car on a rolling Dyno Tune the car around La or Kern County area that wont rip me off and charge me $700.00+ doing so if you know what I mean.
Plus I realy like to know on a real Dyno not on my computer program what H/P & TQ I realy pushing not just on a computer program.
So if anyone out there Knows some where that tunes and has a Dyno please let me know who to get a hold of.
