LTWPS Light
Old May 9, 2002 | 06:45 PM
VERTMAN's Avatar
VERTMAN
Default LTWPS Light
I had to jump start my car Sun. and ever since then my LTWPS service light stays on for about 1/10 of a mile and then goes out. What's up? I read the owners manual but it does not say anything about clearing the light. Should I dissconnect the Batt? Thanks...
Old May 10, 2002 | 05:13 AM
C4TOMCAT's Avatar
C4TOMCAT
Default Re: LTWPS Light (VERTMAN)
first check and see if your tire pressure is correct. should be 35 psi. if it gets to 26+- it will set lite. once the tires build up driving pressure above the 25psi it will be sensed and turn off. if these are ok, then need to troubleshoot as a sensor may be going out. any codes in computer. hope this helps.
