How Do You Race An Automatic?
Old May 9, 2002 | 08:47 PM
Fartsy95vert's Avatar
Fartsy95vert
Default How Do You Race An Automatic?
What is the best way performance wise to race my 95 auto, by (1)manually shifting through the gears, (2) leaving the transmission in Drive, or (3) leaving it in OverDrive?
Old May 9, 2002 | 08:52 PM
jpee's Avatar
jpee
Default Re: How Do You Race An Automatic? (Fartsy95vert)
Best way is leave it in Drive or OverDrive... it will not make any difference in your ET between leaving it in D or OD. But LET it shift itself..
Old May 9, 2002 | 09:33 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: How Do You Race An Automatic? (Red96Coupe)
... But LET it shift itself..
Ab-so-freakin-lootly!!!
It's more "fun" to shift...but your times will suffer. SOP isn't always the best indicator.
Old May 10, 2002 | 11:58 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: How Do You Race An Automatic? (Alchemist)
I usually launch in first and then shift when I know I have traction. If I launch in D and get any wheelspin, it shifts into second and then either bogs down or downshifts and ruins my ET.
Old May 10, 2002 | 01:54 PM
97Supra's Avatar
97Supra
I've had the best luck launching w/ it in second, then shifting to drive before the 2-3 shift but letting it run out and shift on it's own. Manual shifting always slowed it down.
Jason
Old May 10, 2002 | 01:58 PM
J Z06's Avatar
J Z06
I think with the newer cars, like John P mentioned, letting it shift itself will provide the best results(In most cases....it didn't in my car). Don't be afraid to try manually shifting. See what works best for you.
[Modified by JD 90 383, 12:59 PM 5/10/2002]
Old May 10, 2002 | 02:52 PM
payback1's Avatar
payback1
Default Re: How Do You Race An Automatic? (JD 90 383)
Ive always been scared to manually shift an auto, thinking I might break something.
Old May 10, 2002 | 03:10 PM
LayZ's Avatar
LayZ
Default Re: How Do You Race An Automatic? (payback1)
Just for comparison should you bring it to a certain RPM? or just get on it from idle?
Old May 10, 2002 | 03:23 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I got better results by shifting myself, but you will have to try it out for yourself. It more fun shifting yourself, but you'll have to see for yourself.
I go off idle, but for different conditions a powerbreak might turn a better time.
I have to revise my whole system since installing the Vigilante 3200 TC.
Just wish I could get out of CT and get back home to race. This is killing me here!
Old May 10, 2002 | 03:30 PM
cdsmith's Avatar
cdsmith
Put it in (R) for race. Close your eyes and press the gas.
Old May 10, 2002 | 04:14 PM
Fastguy's Avatar
Fastguy
Default Re: How Do You Race An Automatic? (cdsmith)
Hehe, reminds me of my old Grand Prix which had 1, S, and D. S was the "speed" gear.
Old May 10, 2002 | 04:55 PM
Silver Bullet 99's Avatar
Silver Bullet 99
Default Re: How Do You Race An Automatic? (Fastguy)
What kind of Race are we talking about? I've never tried drag racing yet (and cant wait!!) but after running on the new road course at Carlisle, PA two weekends ago - 2nd was fine for me. When I autoX, 1st is usually fine but it depends on how long the main stretch is - you don't want to shift 1/2 in an AutoX heading into a turn because the back in kicks out, or at least it does for me.
When I ran at Summit Point last year - OD was fine and I let the car shift itself. I'm just starting out here so i'm sure other more experienced racers here will chime in.
Old May 10, 2002 | 05:37 PM
GlockLT4's Avatar
GlockLT4
Default Re: How Do You Race An Automatic? (LayZ)
I thought this was going to be a .. i have a standard and need to know how to race against an auto .. i was going to say "YOU BETTER SHIFT FAST!" hehe. Especially against my tranny.
Like others have said .. you should let it shift.. or like fastguy .. do the 1-2 and that's it.
Old May 10, 2002 | 05:44 PM
KYVette90's Avatar
KYVette90
Default Re: How Do You Race An Automatic? (Glock'94)
If you've got a good tach and a shift light, Manually shift that *****! Set your shift light a little low to allow for the delay when shifting.
Old May 10, 2002 | 05:50 PM
Fastguy's Avatar
Fastguy
Default Re: How Do You Race An Automatic? (KYVette90)
Keep in mind the C4 tach is notoriously slow, when you see 5,200, you're closer to 5,700. That's another reason I let it shift itself once I have traction.
Old May 10, 2002 | 05:54 PM
KYVette90's Avatar
KYVette90
My factory tach pegs out at 6k when my Autometer tach is showing 4000, way off.
Old May 10, 2002 | 06:32 PM
John Row's Avatar
John Row
If you are Auto-Xing or Road Racing, learn to brake with your left foot and keep the revs up with the right while cornering then late apex and let her rip.
To How Do You Race An Automatic?
