91' with low tach reading
Old Dec 25, 2011 | 10:26 PM
Allblownup's Avatar
Allblownup
Default 91' with low tach reading
I have a MSD 6AL hooked up and I get a low reading on tach then it will go way up when I rev it up but never steady. Is it bad tach? If so cheaper to used one then fixed? Thanks
Old Dec 25, 2011 | 10:40 PM
rodj's Avatar
rodj
Did tacho work normally with no MSD?
90 /91 well documented for tacho problems
http://forums.corvetteforum.com/c4-g...ch-filter.html
http://forums.corvetteforum.com/c4-g...1990-vert.html
Are you using original tacho hookup or the tach output from the MSD?
Old Dec 25, 2011 | 11:27 PM
Allblownup's Avatar
Allblownup
I have rewired computer...long story, but it used to work fine with MSD. I am just restarting and trying to finish. Has been a problem for a while. I am using MSD output for tach. Thanks
To 91' with low tach reading
