Spare Tire Hanging Assembly
Old May 9, 2002 | 09:49 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Default Spare Tire Hanging Assembly
Does anyone know the part number for the spare tire hanging bolt assembly for my 1994 coupe? The flange that positions whether the spare hangs high or low has snapped off. Anyone have one??? :rolleyes:
Thanks!
Old May 9, 2002 | 10:06 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Default Re: Spare Tire Hanging Assembly (mshipon)
Now that I checked it. The bolt seems to be alright. It's what it screws into that seems to be broken. The bolt is totally frozen and I can't unscrew it though. Any suggestions? :confused:
Thanks Again...
Old May 9, 2002 | 10:24 PM
Rich B.'s Avatar
Rich B.
Is this the 3/4" head bolt at the rear? Not the bent hangers at the two sides?
The one the plastic tray fits into?
Or is the coupe different from convertible?
Old May 9, 2002 | 10:37 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Default Re: Spare Tire Hanging Assembly (Rich B.)
Yep, it's the bolt that the plastic tire carrier hangs on to, but like I said, the bolt is alright. The problem appears to be the bracket it screws into. I think that's the part I need.
Old May 9, 2002 | 11:54 PM
Rich B.'s Avatar
Rich B.
OK, I'm looking at the parts breakdown for the '91 (latest parts book I have).
Bracket, Lat Bolt 88-91 14049218
Kit, Spare Wheel Carrier Mtg 88-91 10089668
The kit has the rear-main bolt & nut & spacers, looks like it might have the side J-bolts, too. ~20.60 at GMPartsDirect, still available...
If you want a scan of the pic, email me...
Old May 10, 2002 | 09:45 AM
Rich B.'s Avatar
Rich B.
Looking at my car, the bolt doesn't really screw into the bracket. The "nut" is on the top of the bracket; looks like the rounded bar on the bottom of the bolt near the head (the bar that fits into the tire tray) except it is threaded. The bolt goes through a hole/slot in the bracket and screws into the top "nut". The bracket holds the "nut" and keeps it from turning.
Is yours stripped (does it turn but not unscrew); or is it frozen (won't turn at all)???
Either way, it would have to be replaced.
Old May 10, 2002 | 06:31 PM
Rich B.'s Avatar
Rich B.
...You gots mail!...
Old May 10, 2002 | 09:34 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Hello Everyone,
I fixed the problem. The bolt was slightly rusted and really stuck in the threaded sleave. After using a little WD-40 and a vise grip, I was able to unscrew the bolt enough to allow me to hang the latch on the upper bracket, thus raising the tire carrier. Once up on the upper bracket, I tightened it up real snug. I removed the license plate to get a better view of the latch and bracket. Once I did that, it all came clear.
Thanks for the help!
To Spare Tire Hanging Assembly
