Power Effects Exhaust - removed
Old May 9, 2002 | 11:36 PM
New N96's Avatar
New N96
Default Power Effects Exhaust - removed
As some of you may recall, the 1996 LT1 CE that I purchased 8 weeks ago had the Power Effects exhaust system on it. While I found the noise to be a bit much with the system set wide open, I very much liked the sound in the closed position. Well the wife thought they were too loud all the time (yes she drives the car), so I put the stock system back on the car. I am amazed at how quiet the car is, almost too quiet for me. Also, I swear the car has lost a little bit of power. Any estimate as to how much HP I lost by putting the stock system back on the car?
If anyone is interested in buying the Power effects system from me (has less than 1,000 miles on it), drop me an email.
Bruce
1996 CE :cheers:
Old May 9, 2002 | 11:52 PM
vader86's Avatar
vader86
Default Re: Power Effects Exhaust - removed (New N96)
you couldve lost 10hp or so, throw a look at Corsa, sounds like its for you
Old May 10, 2002 | 12:01 AM
Jsailor24's Avatar
Jsailor24
Default Re: Power Effects Exhaust - removed (vader86)
When i talked to Joe @ PE he sent me a sheet for the L98 that dynoed at the Rears a 21hp.23ft/lb gain with the system- There is a noticable diffrence between even open and closed IMHO. This system can also go on L98s. You Must buy from PE a diffrent coupler to attach to the cat. For the L98 to LT1/4 swap its roughly a 100$ part.
Old May 10, 2002 | 12:29 AM
DHealey's Avatar
DHealey
You have mail.
To Power Effects Exhaust - removed
