Simple Question
Old Dec 29, 2011 | 06:27 AM
Jason.RG16's Avatar
Jason.RG16
Default Simple Question
corvette 1993, i adjusted the idle srew to lower the engines RPM levels. after i started the car, i checked and it was too low. now im trying to turn the screw the other way but its stuck. is there another way i can turn the screw? i turned the screw using a needle nose pliers, now its stuck. what should i do?
Old Dec 29, 2011 | 07:42 AM
rodj's Avatar
rodj
what should i do?
You may have mangled the threads using the pliers so it wont screw back in
Adjust screw is turned from the rear with a small Torx head bit.
If never been adjusted before ,you need to remove the cap that seals the screw head 1st
Did you disconnect the IAC when adjusting idle?
Old Dec 29, 2011 | 08:48 AM
Jason.RG16's Avatar
Jason.RG16
yeah i did disconnect the IAC. i had the Torx head, but i couldn't find a way to get it in the back, il try with the torx, maybe it will still turn. i hope i dnt mangle the threads too much. Can u specify what number torx? thanks
Old Dec 29, 2011 | 11:15 PM
93Rubie's Avatar
93Rubie
FYI, Those are set at the factory and should not need to be messed with. If you got an idle problem, fix the real issue.
I had a high idle on a buddies 94, because some idiot decided to mess with the stop, caused all kinds of grief.
I think it is a T20, and it is a tamperproof torx not a regular one. Has a raised bump in the middle of the torx pattern.
Old Dec 29, 2011 | 11:19 PM
leesvet's Avatar
leesvet
You do NOT adjust that screw. Thats why GM placed a safety torx there...dimple torx so you could not mess with it.
Let the IAC do its job if the rest of the engine is set correctly.
No bubba tuners here,.
Old Dec 31, 2011 | 12:56 AM
Cliff Harris's Avatar
Cliff Harris
I disagree that the minimum throttle opening shouldn't ever need adjustment. I always felt the same way until my car started dying at idle. I did the minimum idle adjustment and have never had a problem since then. Mine is a regular Torx T-20, not a security type.
I think the linkage becomes worn over time and allows the throttle plates to close more than they should. On my car there is definitely some metal deformation where the adjusting screw contacts the linkage.
Old Dec 31, 2011 | 08:54 AM
sailorsteve's Avatar
sailorsteve
One issue that can lead to high idle after many miles is wear on the throttle plate shaft. This allows extra air into the plenum, then the ECM adds fuel to reach stochiometric air/fuel mixture, resulting in high idle speed. You can diagnose this by reading the "counts" value for the IAC with a scanner, if the valve is closed, and the idle is too high, look for an air leak around the throttle body, or a vacuum leak elsewhere. You can also do a crude representation of this test by removing the air inlet and carefully taping over the bores, but not the little hole between them, to see if there is any major change to the idle speed.
Old Dec 31, 2011 | 06:46 PM
93Rubie's Avatar
93Rubie
This issue is the only one in my book that adjusting the minimum idle speed screw is legitimate. Or you could get a new throttle body.
Old Jan 1, 2012 | 02:43 AM
96GS#007's Avatar
96GS#007
Just to be clear, the OP was attempting to adjust the idle speed via the screw on the throttle body. The idle speed is programmed into the ECM. The screw adjusts minimum idle air so that the IAC is within range.
Old Jan 1, 2012 | 02:52 AM
rodj's Avatar
rodj
http://forums.corvetteforum.com/1548110758-post6.html
Most often mentioned method for idle adjustment
https://www.corvetteforum.com/techti...D=55&TopicID=2
Revised vesion
http://www.corvetteactioncenter.com/...-corvette.html
To Simple Question
