90 blocks 2 or4 bolt? journals too?
hey is the 1990 vette block a 2 or 4 bolt, also a small or large journal crank? doing a rebuild soon & just curious what all i have? guessing a fluid damper would be my best bet using the stock crank after balancing?
Re: 90 blocks 2 or4 bolt? journals too? (gtsyellow)
All the L98's that came in vettes were 2 bolt main. The only 4 bolt main blocks(roller, 1 pc rear main) were in the trucks of the same years.
Cruise-In VII Veteran
Re: 90 blocks 2 or4 bolt? journals too? (VetteBabe1)
Not quite true. I have a 350 GTA that came with a 4 bolt one piece rear roller block. I know the '87 and '88 350 F-bodies have the 4 bolt. I'm not sure about the later ones.
Re: 90 blocks 2 or4 bolt? journals too? (SloRvette)
:lol: nice no one really knows for sure..oh well i can pull it apart and look. i'm sure with the 350-360hp/NA i'll make either or will live even with the 100shot in the plans.
The f-body 350s have 2 bolt. I've had mine apart a half dozen times, '88 350,
2 bolt, thats all of the L-98s.
Gary
Gary
