Header Install on a 95 LT1..
Old Jan 1, 2012 | 11:53 AM
LannyL81's Avatar
LannyL81
Default Header Install on a 95 LT1..
Thinking about putting a set of shorty headers onto my '95 LT1...had 138k miles on it.
For anyone that has done this with the engine in the car can you tell me:
1) is there enough room to get the exhaust manifold bolts out?
2) the chances of breaking one of the exhaust manifold bolts in the head?
Just wondering since I still have everything off from the flywheel on back...so I have a little extra room.
Old Jan 1, 2012 | 12:07 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Yes
Yes, it does happen once in a while.
Old Jan 1, 2012 | 12:52 PM
1963SS's Avatar
1963SS
James has it right. There is a chance of a bolt breaking. Start spraying it with PB Blaster now and in a couple of days your chances will be better of not breaking one.
Old Jan 1, 2012 | 01:31 PM
aminnich's Avatar
aminnich
Why not long tubes??
Old Jan 1, 2012 | 03:54 PM
LannyL81's Avatar
LannyL81
Shorty Headers: $125 used
Long Tube: $$$$$$$$$$$$$$$
Old Jan 1, 2012 | 05:11 PM
mmracecars's Avatar
mmracecars
same thing i did,but used a brand called kroil,seems to work better the pb.its avail online from kano laboratories.its more expensive.but id had only used PB blaster,till some others convinced me to try it,and havent used anything else since.soaked all the bolts every morn and night for a week in my 95and every bolt came out.
Old Jan 1, 2012 | 06:07 PM
LTxDave's Avatar
LTxDave
Didn't soak any bolts in my 95 and all came out with no problems. Even after 220k miles.
Old Jan 1, 2012 | 06:26 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Shorty's will give you little to no hp gain. Not worth the time imo... Even LTs don't give much until you add other complimenting mods. That said, my bolts came out with little problem, but I soaked them overnight with PB Blaster.
Old Jan 2, 2012 | 08:39 AM
LannyL81's Avatar
LannyL81
I will not be putting any shorty headers on....there is not enough time to get the headers here and installed before next Sat and I pretty much agree that there is no gain. I was just going to do this since I have the transmission and clutch out.
I also thought about putting a Hurst short shifter in. Sure would be easier with the trans out....but again out of time.
Thanks for all the replies.
Old Jan 2, 2012 | 09:42 AM
STL94LT1's Avatar
STL94LT1
The Hurst would be worth the wait!!
Old Jan 2, 2012 | 04:12 PM
LannyL81's Avatar
LannyL81
Yeah...I know....I have one in my '96 LT4 and it is wonderful....
To Header Install on a 95 LT1..
