Irratic fan problems
Old May 10, 2002 | 12:12 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Irratic fan problems
I have a problem with my electric fan. You see, It turns on whenever it feels like it. Sometimes it turns on right as I start the car up in the morning. Other times it turns on when coolant temp. is around 140 and 180. What gives? Do I have a bad relay or something? Can it be a problem with the computer? Help me out. Thanks.
Old May 10, 2002 | 01:05 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Irratic fan problems (NUckINg FuTS)
This is going by my 87 manual.
Try disconnecting the fan relay and see if it stops or keeps going. If it stops it could be a short in the DRK GRN/WHT wire, faulty ECM or a faulty relay and if it doesn't it could be a shorted BLU/PNK wire. Not sure if the wire colors are the same for 86 and 87 but HTH.
[Modified by War Machine, 11:06 AM 5/10/2002]
Old May 10, 2002 | 06:43 PM
NUckINg FuTS
Default Re: Irratic fan problems (War Machine)
Can anyone else add to this???
Old May 10, 2002 | 08:07 PM
ittlfly's Avatar
ittlfly
Another thing you might look at is the A/C pressure sensor. If it is out of range, it will cause the fans to operate at the wrong times. As th eother post mentions, it could be a short to ground causing the relays to close. In the 92 manual, its the dark blue/white and dark green/white from the relays.
Old May 11, 2002 | 02:45 AM
dlmeyers's Avatar
dlmeyers
I'll start with the simple and cheap. Check the resistance on your engine coolant temp sensor and compare with the value in the service manual. Not sure about the 86 but suspect the computer (ECM)provides the ground for the fan relay based on temperature signal from the coolant temp sensor. They are a negative temperature coefficient thermistor and can get out of whack. Be sure to use a pretty good digitial volt ohm meter (DVOM).
Keep the faith.
dlmeyers 90 coupe zf6 3 speed shocks
To Irratic fan problems
