ODB(??) Edit
Old May 10, 2002 | 03:35 PM
vvv90's Avatar
vvv90
Default ODB(??) Edit
I hope I'm not bringing up a subject that's been around for a while, but I'm new, cut me some slack. :)
Anyway, I have a '92 LT-1 I'd like to learn a little about programming my ECM with a program I've heard called ODBII Edit. Only, the links I've seen are for 94-96 year models.
what do you guys recommend for resources on this subject??? :seeya
Old May 10, 2002 | 03:37 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: ODB(??) Edit (vvv90)
Your 92 is OBD 1.. check the PROM forum here for tons of info.
As for Diagnostics software.. there are some nice free ones and also others that cost around $300
Old May 10, 2002 | 03:56 PM
vvv90's Avatar
vvv90
Default Re: ODB(??) Edit (-=Jeff=-)
Oooh yeahh!
Can you tell I'm new :crazy:
Old May 10, 2002 | 04:16 PM
Jimmy69's Avatar
Jimmy69
Check out http://www.tunercat.com
Your LT1 still uses a chip, the 94 & up are FLASH based.
Jimmy
To ODB(??) Edit
