I-pad for tuning
Old Jan 5, 2012 | 09:30 PM
oldalaskaman's Avatar
oldalaskaman
Default I-pad for tuning
anyone using an ipad for doing the tuning/chip reprograming. tryin to figure out if it would work or get fried? thanks bob
Old Jan 6, 2012 | 12:06 AM
rodj's Avatar
rodj
The commonly available tuning software is Windows based so you need a device that will run Windows Apps
http://forums.corvetteforum.com/c4-s...3-android.html
Old Jan 6, 2012 | 12:19 AM
oldalaskaman
many thanks
Old Jan 6, 2012 | 01:29 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Shoot a pm to england green - he is the resident Apple expert
Old Jan 6, 2012 | 03:29 PM
oldalaskaman
great info, many thanks, bob
Old Jan 6, 2012 | 11:32 PM
Crepitus's Avatar
Crepitus
I have been hopeing to use one for a gauge cluster (bar graphs would be fine) and maby data logging.
Old Jan 7, 2012 | 12:07 AM
Dr.Huxtable's Avatar
Dr.Huxtable
This would be awesome! I have the Ipad2 and that would be sick to be able to use for tuning. If you find somethin out bob let me know!
Old Jan 7, 2012 | 03:26 AM
Cliff Harris's Avatar
Cliff Harris
I have a OBD-II to WiFi adapter. Works with my iPhone and ought to work with an iPad. There are several apps available that work with this gadget. FuzzyCar and FuzzyCode are two that come to mind. There is also one called "Rev" or something like that. You can't send TO the ECM, but you can monitor stuff.
http://www.plxkiwi.com/kiwiwifi/
There is an application for Macs that runs as a Python program. It was written for UNIX boxes. I don't remember the original name. I adapted it for Mac OS X and changed the name to MacOBD-II. The original developer abandoned the project and left it in an unworkable state. I fixed most of it and it now displays the parameters correctly. One problem it has is that it will not display DTCs - Diagnostic Trouble Codes. The original author faked the codes -- the ones he displayed don't actually come from the ECM. I don't know the protocol for querying the ECM to retrieve DTCs. Source code is included, so you are free to modify, improve or whatever. You must have MacPython and wxPython installed and a OBD-II to USB converter cable to run this app:
http://www.misterpeachy.com/OSX/OSX.html
----------- [ EDIT ] ----------------
FuzzyCar has disappeared. The web site no longer exists.
There are two versions of Rev. Rev Lite and regular Rev. I don't think Rev Lite will display error codes.
The original Python program was called pyOBD, written by Donour Sizemore. Apparently he wrote it as a senior project at the university he was attending. From what I could tell, he was using a UNIX computer to run the program.
The error code section of the program apparently looks for error codes and if it finds none it just displays a bunch of sample errors. The author insists that the error code section DOES work correctly, but I have not seen that. My car doesn't have any errors to display, so that could explain it. I guess the only way to find out is to disconnect something and see what happens...
----------- [ /EDIT ] ----------------
Last edited by Cliff Harris; Sep 6, 2016 at 12:29 AM. Reason: Added updated information.
Old Jan 9, 2012 | 12:44 AM
oldalaskaman
many thanks for the replys
To I-pad for tuning
