Injector question
Old Jan 7, 2012 | 12:09 PM
93cruiser's Avatar
93cruiser
Default Injector question
Will 94 factory injectors work in a 93? Everything looks the same but not sure of the electical requirements.
93cruiser
Old Jan 7, 2012 | 12:34 PM
ddahlgren's Avatar
ddahlgren
93cruiser
Without doing the small amount of work for you why not just look up the replacements and see if the same part numbers are listed for both.
Old Jan 7, 2012 | 12:58 PM
leesvet's Avatar
leesvet
or go to most any parts store website and search the parts and note any differences. They have the spec listed and compatable yr make and model.
Old Jan 7, 2012 | 01:04 PM
93cruiser's Avatar
93cruiser
Thanks for the replies.
Old Jan 7, 2012 | 01:19 PM
Jimbo 89's Avatar
Jimbo 89
93cruiser
If they are the factory Multecs, I wouldn't use them.
Old Jan 7, 2012 | 10:20 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
93cruiser
Will they work - yes, you may need a tune to optimize them
The 92/93 injectors have a slightly lower gph rating. IIRC 92/92 was 22ish and the 94 was 24 ish.
Old Jan 8, 2012 | 09:48 AM
93cruiser's Avatar
93cruiser
Thanks for the info. I have a no start condition. I am getting spark so I checked fuel pressure. I get 45 psi but it does not hold. I followed the flow chart in the Fsm and the result of that exercise is that i have a leaking injector. I was unable to determine which one it is thus far. I am going to check the impedence on each injector to see if one of them is electrically bad. From reading on the forum, it seems possible that one bad injector coil could bring the lot down.
I asked the original question because I thought of changing them all out with a set of 94 injectors that I have.
Thanks again
93cruiser
To Injector question
