Engine idle issue, Hunting
Jan 7, 2012 | 07:05 PM
Been working on this for several months. After replacing a head gasket, I started having problems withe the engine hunting while idle. I replaced vacuum lines, set timing, replaced plugs, wires, distributor, coil, etc.. The engine still wants to hunt between 6 & 8 rpm. Any new ideas?
Jan 7, 2012 | 07:19 PM
Have you checked for leaks at the intake manifold?
Jan 7, 2012 | 09:37 PM
Quote:
Originally Posted by
1986coupe
How ho I check for leaks at the manifold?
Jan 7, 2012 | 10:23 PM
Jan 7, 2012 | 10:25 PM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Bredd1
check for loose or broken vacuum lines, evap lines..
Jan 7, 2012 | 10:35 PM
pewter99
Holy moly. Looks who's posting in C4 tech.
Jan 7, 2012 | 11:58 PM
oldalaskaman
slow egr
Slow EGR?
Jan 8, 2012 | 08:01 AM
What do you mean slow EGR?
Jan 8, 2012 | 09:49 AM
Bredd1
What year? I would also check the IAC. If the problem started after the work was done, 9 times out of 10 there is a relationship.
Jan 8, 2012 | 04:05 PM
sailorsteve
I pulled off the throttle body, cleaned it and replaced the IAC. Also went through proceedure to set idle speed and set TPS to .54 volts.
Jan 8, 2012 | 06:37 PM
if the egr is cruded up it will function slowly, causing your idle to flucuate
