Need some help..
Old Jan 8, 2012 | 11:05 AM
Iown1badvette's Avatar
Iown1badvette
Default Need some help..
I live in Jersey(Northern) and I'm looking for a rear, Ive been on the hunt for a year now, I'm looking for a Dana 44(G92 option) with the 3.07 gears, I'm glad I'm still looking because I don't know how much $$ I should dish out. What to look for, is there a code stamped on the pumpkin? If I were to find one, how would I know it has 3.07 gears? Can I check/inspect the teeth? This is my last and final major piece for my vette and I want to make sure I do it right
P.S my vette told me she loves me
Old Jan 8, 2012 | 11:35 AM
STL94LT1's Avatar
STL94LT1
http://forums.corvetteforum.com/c4-p...-for-sale.html
Old Jan 8, 2012 | 11:39 AM
Iown1badvette
wow good looks!
So I'm just guessing a Dana 44 with 3.07's should be no more than 1,200 bucks?
Old Jan 8, 2012 | 12:39 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Found on 85 to 88 with the 4+3 trans.
I'm glad I'm still looking because I don't know how much $$ I should dish out.:
I would say $1000 to $1500, but under $1000 can be found.
You need to find the batwing, pumpkin with gear, C beam and drive shaft.
The build date and gear ratio is usually written on the bottom of the pumpkin.
You can count the teeth on the gears to figure out what gear it has.
Old Jan 8, 2012 | 01:27 PM
Iown1badvette
This is the response I was looking for, thank you both for the help
To Need some help..
