Well I got the Clutch hydrolics all fixed now its time to try to fix the tranny issue.. There is a very loud whine when you are in the manual drive mode but as soon as you go into OD the Whine goes away. The Whine is always there from the time you leave in 1st gear untill you activate the OD unit. The whine is a constant. Does not matter if you are accellerating, slowing down, shifting or just having the tranny in neutral while slowing down to a stop. The Whine is there when the Clutch pedal is pushed in as well. If the car is moving and its not in OD there is a whine basically.. I changed out the fluid today and there was some metal on the magnet drainplug. I used 80W90 gear oil.. I am thinking its a bearing issue inside the MT. The car is a 86 with 71,600 miles on it..
It sounds like it's the front annular carrier bearing in the OD unit? The carrier has the pinion gears that produces OD. Just a thought.
I checked out the whole 4+3 section here and really learned a lot. Everybody with this tranny should check out this link.
Some more bedtime reading from 1998. http://www.5speeds.com/archive/27.html
Suggest you make notes or cut and paste for reference as no idea why this archive is still available;
it is not accessible from the 5speed website
As noted elsewhere 5speeds sold their 4+3 parts /service to SK Speed
