LS swap
Old Jan 9, 2012 | 11:40 PM
JackDidley's Avatar
JackDidley
Default LS swap
Maybe a dumb idea. Anybody consider this ? When doing an LS swap in an early C4, seems like you could use a cable operated throttle body, and an HEI with this:
http://www.ebay.com/itm/GM-Performan...r#ht_500wt_969
Then you could run it off the stock ECM (with a tune) and avoid all those wiring and interface problems. Yes, I know it would be batch fire and low tech, but it would make things simple.
Just an idea, running around in my twisted mind.
Old Jan 10, 2012 | 07:14 AM
PAINTER MAN's Avatar
PAINTER MAN
Looks like that is a prototype and never tried. It is also the only one available.
Old Jan 10, 2012 | 08:56 AM
subtlez28's Avatar
subtlez28
I like simple. But it seems like to big of a step backward ECU wise (for me).
Old Jan 10, 2012 | 09:09 AM
JackDidley's Avatar
JackDidley
No, you can get them from Summit or any GM dealer. Guys have converted LS motors to carbs for quite a while using this.
Old Jan 10, 2012 | 07:45 PM
93Rubie's Avatar
93Rubie
As I was reading this, exactly what I was thinking. They offer stand alone electronic spark control as well (w/o distributor). Designed to work with a carbed LS.
Old Jan 10, 2012 | 10:24 PM
JackDidley's Avatar
JackDidley
I have no need for an LS swap but the idea seems worth putting out there since the ECM/wiring issues can be a problem for some.
To LS swap
