LT1, "Free Mods"
Old May 10, 2002 | 11:44 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default LT1, "Free Mods"
Ok, i'm putting a short list together of a few things i can do, at small cost to increase power..
1. K&N Filter
2. Cut open front of air intake(cut off baffles)
3. take off MAF screen
4. Relocate MAT
Thats just the short list. Eventually i want to put on the corsas, and possibly(and i struggle with this because i love my heat) a 160deg thermo.
How much power should i gain with steps 1-4? 10hp? 20hp? more? :)
Old May 11, 2002 | 12:05 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: LT1, "Free Mods" (Mervz)
I liked the TB bypass and 160 stat combo. :yesnod:
Also did a chip to handle the fans and kill CAGS.
Stock mufflers are nice. They're in a box in the garage. :lol:
Old May 11, 2002 | 01:45 AM
vader86's Avatar
vader86
you might gain anywhere from 5-10hp from that, when you do the 160 be sure to do the bypass
I dont like the MAT relocating, it just doesnt seem right to do it, youre just lying to the computer and not gaining a whole lot from it.
Old May 11, 2002 | 03:41 AM
Red94Vette's Avatar
Red94Vette
Default Re: LT1, "Free Mods" (vader86)
The sensor is getting heat soaked from the radiator, it's not the true air temp. I have some logs of the IAT and it falls as I'm on the gas (it's cooling the temperature down to the REAL air inlet temp.
Here's a log, the blue is the air inlet temp. Notice it drop during the run. It thinks it's 112F at the start and by the end of 3rd it reads 101F. BTW, the real outside temp was 83F.
But still I don't think you will gain anything from it unless you run speed density. MAF cars do not use the air inlet temp in the fuel calculations, it just uses the MAF sensor.
Speed density cars are guessing at the incoming air by using RPM and the manifold pressure so it needs the temp to correct for the right amount.
[Modified by Red94Vette, 7:57 AM 5/11/2002]
Old May 11, 2002 | 09:59 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
To be perfectly honest, you won't gain much if anything, and if you do, you certainly won't "feel" it.
Old May 11, 2002 | 10:50 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default Re: LT1, "Free Mods" (Mr Mojo)
Been there and have done all that and I feel the same way. :yesnod:
Old May 11, 2002 | 12:50 PM
Lone Ranger's Avatar
Lone Ranger
I thought removing the MAF screen was a no-no? Or at the very least, a no-gainer?
Old May 11, 2002 | 01:16 PM
vader86's Avatar
vader86
Default Re: LT1, "Free Mods" (Lone Ranger)
Removing the screens are fine, but removing the heat sinks inside is somthin you dont want to mess with. You may or may not gain anything from it, its better to do this after you require the air that youre freeing up by removing the screens. (like intake manifold, heads, cam) Mojo doesnt show gains on anything bc his girl is a monster and hes a good driver already.
Old May 11, 2002 | 01:19 PM
Red94Vette's Avatar
Red94Vette
It will mess up the calibration of the MAF if you remove the screens. I had to re-calibrate mine in the low flow range 9-12 grams per second. The MAF was reading too high and adding too much fuel (engine was rich and computer had to remove fuel for 14.7:1 ratio)
For example, the MAF was reading 9-10 grams per second of air and in realitiy only 8 grams per second was entering. The computer tried to add enough fuel for 9-10 grams when really only 8 was going in (too much fuel). I changed the MAF calibration so the BLMs read 128 at idle, works great again.
While driving down the road at around 40 grams per second the BLMs are around the 127-129 range so the MAF works fine in that range. It seems to only screw up the low flow range.
To LT1, "Free Mods"
