Engine swap info, please.
Old Jan 13, 2012 | 12:07 PM
tusairon1's Avatar
tusairon1
Default Engine swap info, please.
I need to know if someone can tell me from the info given here(350 CHEVY SHORT BLOCK
COMPLETE WITH OIL PAN
CAN BE RUN AS IS OR GOOD CORE TO REBUILD
1 PIECE REAR MAIN SEAL 90'S VINTAGE) Can I put my intake and heads on this short block and have it work in my 87 C4? The pistons look like flat tops with valve reliefs. Thank you for any and all help! Troy.
Old Jan 14, 2012 | 06:38 AM
rodj's Avatar
rodj
Block is same as your '87
Will need your oil pan and oil pickup
Compression may vary dependent on how different the pistons are to the ones in your engine
May or not be roller cam;
many 1 pce blocks machined for roller cam but fitted with flat tappet cams when installed in trucks
Old Jan 14, 2012 | 09:25 AM
tusairon1's Avatar
tusairon1
Default Engine swap
The guy that has this block gave me these numbers and I can't find them any where. K1024FBM and THS506071. I'm thinking it's an early to mid 90's 4 bolt main 350. How can I tell if it is machined for the roller cam?
Thanks,Troy
Old Jan 14, 2012 | 09:30 AM
tusairon1's Avatar
tusairon1
What I'm trying to do is build a 383. I'm going all forged lower end. Porting my heads to match a FIRST intake and would like to get a bigger roller assembly.
Old Jan 14, 2012 | 06:43 PM
rodj's Avatar
rodj
K1024FBM
Engine Suffix FBM : 1987 350 L05 Truck 170 Hp TBI
Will have the flats machined above the lifter bores and the 3 pedestals for the lifter retainer spider threaded
Old Jan 15, 2012 | 08:54 PM
tusairon1's Avatar
tusairon1
Block does not have the flats machined. Can I get this done.
To Engine swap info, please.
