u joints.., replace proactively or only if they are broken
Old Jan 16, 2012 | 07:39 PM
dizwiz24's Avatar
dizwiz24
Default u joints.., replace proactively or only if they are broken
I've got my 93 diff removed to replace bad batwing bushings.
While its apart, would you replace the u joints? Car has 60k miles and is a 6 spd.
There appears to be nothing wrong w/ any of the u joints on either halfshafts or the driveshaft.
Id hate to replace a fine 'made in usa' part with a po$ 'made in mexico' part.
What would you do if you were me?
Old Jan 16, 2012 | 07:44 PM
93Rubie's Avatar
93Rubie
I'd replace them, find some actual Spicer units and replace while you got it apart. Considering your adding HP, a good idea.
DO NOT GET GREASE ABLE U-JOINTS, they are weaker. This is a performance car right, not a stupid truck.
http://www.dennysdriveshaft.com/c29_corvette.html
Old Jan 16, 2012 | 08:10 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Just did mine....
Old Jan 16, 2012 | 08:23 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Might as well do it since it's apart.
Old Jan 16, 2012 | 08:49 PM
1991Z07's Avatar
1991Z07
I'm doing that right now. Thought I had a u-joint going and when I got it on the lift it was a wheel bearing. But, since they have >40k miles on them ALL, I'm going to replace everything while it's apart.
Spicers are only about $25-$30/ea. so it isn't a huge expense either.
To u joints.., replace proactively or only if they are broken
