Quick question about rear lowering kit.
Old May 11, 2002 | 06:37 PM
ZBRA's Avatar
ZBRA
Default Quick question about rear lowering kit.
I have already done a search and found contradicting answers.
Q: On the rear bolts, to lower it do you tighten the nuts way up or leave the nuts close to the end of the threads?
Since the bolts are longer, I would assume that you use the extra length and just barely screw the nut on. Am I right? I hate to assume.
Old May 11, 2002 | 06:40 PM
ZBRA's Avatar
ZBRA
Default Re: Quick question about rear lowering kit. (ZBRA)
I'm assuming that this is the correct way:
rather than screwing the nut as far up as possible?
Old May 11, 2002 | 06:51 PM
Mr. G.'s Avatar
Mr. G.
You are correct.
Old May 11, 2002 | 06:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's right. As you raise the nut you raise the rear of the car; lower the nut to lower the car.
Look at the rear suspension setup and you see that the spring end mounts are below the rear wheel mounts and so the spring hangs from the rear wheels by those bolts. The spring is attached to the body so the body essentially hangs from the rear wheels. The farther the nut is from the upper wheel mount the lower the body hangs.
Measure the separatsion distance from the top of the rear spring to the bottom of the wheel mount with the stock setup. Add the amount you want to lower the rear and that's the new separation distance.
After you lower the rear the desired amount, drive the car a short distance before you measure the new ride height as the wheels will be tilted just after you remove the jacks and driving the car will allow them to come back to their normal camber setting.
Old May 11, 2002 | 07:28 PM
ZBRA's Avatar
ZBRA
Default Re: Quick question about rear lowering kit. (65Z01)
:cheers: Thanks guys. She's looking better already. :cheers:
To Quick question about rear lowering kit.
