Compression test
Old Jan 17, 2012 | 07:09 AM
JAKE-SON's Avatar
JAKE-SON
Default Compression test
Hi, looking to do a c. Test on my car and looking.tonsee what my numbers should.be around. Have 401 lt1.
3.875in forged.eagle.crank
6in scat forged rods
-4cc flat top forged.probe.srs.postons
Dart.pro.1, 180 heads, 58cc
290/306 advertised duration cam shaft, 110 lsa.
le ported intake
All I cam remember off top of my head, typing In parking lot
Ryan M.
Old Jan 17, 2012 | 10:20 AM
1963SS's Avatar
1963SS
It will be hard to figure out unless we know how many degrees after BDC the intake valve closes. That changes everything.
Old Jan 17, 2012 | 11:46 AM
tombrammer's Avatar
tombrammer
What are you trying to find out? From what I know it's the difference between all 8 cylinders, not the actual number itself. If one cylinder is off a bunch from all the others then that cyl. is suspect. A leak down test is better for determining engine condition, rings, valve seal, etc. By the way very nice car! The compression tests I have done on 350's have been in the 190 - 195 range.
To Compression test
