Please help! I got the shakes
Old Jan 17, 2012 | 09:34 AM
1985c4vette's Avatar
1985c4vette
Default Please help! I got the shakes
1985 c4 5.7L coupe 4+3 manual trans. Has a shake at idle (like big engine shake from side to side slow), but while accelerating in each gear it gets worse as you push on pedal. If I turn on the overdrive(+3 part) in fourth gear it feels like the car is going to jump apart (only when you push the pedal). I have checked the timing (@ 6 degrees BTDC), all new distributor cap, rotor, coil, plugs (gaped @ .0035), wires (all double checked), throttle positioning sensor, and valve cover gaskets. Any ideas? Thanks! Scott.
Old Jan 17, 2012 | 11:26 AM
1985c4vette
I have double and triple checked the firing order both online and haynes manual. Thank you. It did this before for about three days then stoppped but since I re placed the above parts it has come back and seems to be here to stay. I'm lost.
Old Jan 17, 2012 | 12:24 PM
sailorsteve's Avatar
sailorsteve
Broken motor mount(s)?
Old Jan 17, 2012 | 12:44 PM
1985c4vette
I'm going to check motor mounts and transmission mounts. Sounds plausible. Thank you.
Old Jan 17, 2012 | 12:59 PM
sailorsteve
There are no "transmission mounts". There are two motor mounts, and the trans has a "c-beam" that covers the driveshaft and attaches from the rear of the trans to the diff housing, thus supporting the trans as well as the engine. The bolts on this could be loose, and while you're under there, check the trans-to-engine bolts to see if they are tight.
Old Jan 17, 2012 | 01:12 PM
1985c4vette
Ok thank you.
Old Jan 17, 2012 | 06:56 PM
popo8's Avatar
popo8
First I think we need to know if you have an idea if the shake is a "motor running" issue, or if it is a physical issue with the vehicle (IE: mounts as stated, DS out of balance, etc...)
Are you getting any SES light?
Old Jan 17, 2012 | 08:07 PM
1985c4vette
I'm sorry, i am totally new (just a few months) to owning a corvette. i don't know what a "DS" or "SES light" is.
At idle, it shakes like a side to side roll. with out the overdrive on it feels like I'm in to high a gear for the speed (remember 4 speed +3 Manual) (only when I push down the pedal, if i stay at steady speed it feels fine),I'm not. If I turn on the overdrive and push the pedal and it gets real shakey like I just ran over a metal grate (real bad feeling).
Old Jan 17, 2012 | 08:10 PM
1985c4vette
Guys and Gals, I do wish to Thank You all for your help. It 's great to find a place like this where people will help. You people are Great.
Old Jan 17, 2012 | 08:27 PM
popo8's Avatar
popo8
DS= Drive Shaft
SES= Service Engine Soon (commonly known as a check engine light)
Old Jan 18, 2012 | 11:42 AM
1985c4vette
No issues with the drive shaft. Rpm's were running up to 1600 at idle and check engine light would come on. This is what lead me to replace the throttle positioning sensor. Have have it happen twice since. Shut off engine and restart light went out and rpm's returned to normal.
Old Jan 19, 2012 | 06:57 AM
kenmohr's Avatar
kenmohr
Originally Posted by DaveP85C4
Firing order?
Yep Recheck very carefully
Old Jan 19, 2012 | 09:05 AM
1985c4vette
ok this is the firing order i used 1,8,4,3,6,5,7,2 clockwise on the distributor. On the engine, from front left 1,3,5,7 from front right 2,4,6,8
Old Jan 19, 2012 | 10:45 AM
95tripleblack's Avatar
95tripleblack
Old Jan 19, 2012 | 01:03 PM
1985c4vette
I have a 1985 c4 L98 5.7L, but the order on the block looks the same. I have checked the firing order on the car again and it seems to be correct. I work at a VW dealer (sales) and we have a Cadillac (GM) dealer in our auto group. I made an appointment to have a diagnostic done on the car. I was hoping to not have to pay to figure this out (yes employees still have to pay). Thanks for all your help. I'm sure I'll be on here a lot, as I'm new to corvette and have a lot of work to be done on this car. This is how you learn right.....
Old Jan 19, 2012 | 02:57 PM
sailorsteve
Well, a competent tech onsite has an advantage over CF diagnosis by remote control. (Notice I said, "competent") Let us know what turns up.
To Please help! I got the shakes
