black smoke
Old May 11, 2002 | 10:52 PM
C4Cvette's Avatar
C4Cvette
Default black smoke
I have been told by more than one person that when I get on it, my car smokes quite a bit. I have also seen this in the rear view. The car is a stock LT1 with 62k on it. The car also seems to run great, but the smoke worries me a bit. Also when the car idles, it smells like it is running rich, or the previous owner gutted the cats.
Old May 11, 2002 | 10:53 PM
scorp508's Avatar
scorp508
Black = Fuel
Sounds like you're running rich. :)
Old May 11, 2002 | 10:55 PM
C4Cvette's Avatar
C4Cvette
Default Re: black smoke (C4Cvette)
my thoughts exactly, now how to fix it. Fuel pressure? It also has the stock regulator.
Old May 12, 2002 | 10:22 AM
C4Cvette's Avatar
C4Cvette
ttt
Old May 12, 2002 | 10:30 AM
ittlfly's Avatar
ittlfly
The first step is check to see if any codes have been set. It could be that the O2 sensor(s) are bad sending a lean signal in closed loop to the ECM causing it to increase fuel. There are several other possibilities tho. Rather than throwing parts at it, check for codes first. :yesnod:
To black smoke
