Question about roller rockers
Old Jan 19, 2012 | 10:52 AM
great68's Avatar
great68
Default Question about roller rockers
Can you put just roller rocker arms on any motor, or do you have to have a special cam, rods,etc...
Old Jan 19, 2012 | 01:00 PM
toptechx6's Avatar
toptechx6
Nothing else required, however if you increase ratio with the rocker arm change most recommend changing valve springs to avoid spring bind.
Old Jan 22, 2012 | 03:52 PM
Crepitus's Avatar
Crepitus
watch valve cover clearance
Old Jan 22, 2012 | 09:52 PM
blkzr1's Avatar
blkzr1
Default rockers
hi, if you change your rockers to roller rockers, you may also want to check your pushrod length to ensure correct geometry. see ya
To Question about roller rockers
