Finding a warped rotor without a micrometer?
Old May 11, 2002 | 11:32 PM
bac22's Avatar
bac22
Default Finding a warped rotor without a micrometer?
My brakes are vibrating when doing braking from 55 MPH and above. I'm guessing it is a warp rotor, but I don't know which one. Any tricks to finding one without a micrometer? It feels like it is in the rear, but I don't know which side.
I may just buy new rotors, where is the best place and price to get stock rotors from?
Thanks.
Old May 11, 2002 | 11:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Finding a warped rotor without a micrometer? (bac22)
By all means replace the rotors in pairs.
On the front you could simply spin the wheel and listen as someone lightly applies the brakes; not sure how to do this test out back though.
Old May 12, 2002 | 01:22 AM
jfb's Avatar
jfb
You can buy a micrometer for $25. That may not show the rotor condition, so also buy a dial indicator and you can get one for under $25 too. Rotor thickness should not be less than .745 inch and if thicker, they can be turned. I have had reasonable life after turning. Of course my mechanic knows what he is doing and the last time he did this, he removed only .002 inch to straighten them. Some ham fisted mechanics take way too much off the rotors and that shortens their life.
Old May 12, 2002 | 04:25 AM
merrick's Avatar
merrick
If you can't tell if it is warped by just spinning the wheel then try this: Remove the wheel and reinstall a couple lug nuts to hold the rotor firmly. Set something (like a jack stand) against the side of the rotor and turn the rotor. Any warpage should be visible. Do both sides of the rotor.
Old May 12, 2002 | 11:19 AM
6spd89's Avatar
6spd89
Default Re: Finding a warped rotor without a micrometer? (jfb)
Dial indicator is the only way to check for an out of parallel condition.
Micrometer will just tell you how thick the rotor is,you can buy
an indicator w/a magnetic base and place it on something solid and flat,
and slide it up to the car,then spin the rotor and walla-she is warped!!
Just clarifying what was said above,you will need a thousands indicator
(.001")versus a (.0001").
Matt
To Finding a warped rotor without a micrometer?
