PCV System Details
the car in question has a stock L98 motor, 1990 6sp which is autocrossed regularly.
Engine has been resealed. Performance / power is excellent. However since all the leaks have been sealed I have noticed I pump oil out the dipstick.
I have searched the numerous threads here and other sites, and feel I am not getting enough pull off the PCV under WOT. I have brand new AC Delco PCV valves and fresh hose, nothing blocked. Was thinking of cutting in a breather but I a couple of the threads implied that one side the PCV sucks and the other it doesn't, not sure why I it would work that way. Seems to me that both the line running to the throttle body area and the other to the manifold.
What I was considering doing is putting a breather element in line between the PCV valve and the intake, with a T that can be capped for street driving but opened for track and autocross events.
Thoughts, examples of other solutins?
through the airfilter/MAF (metered)
tee'd off line to pass side valvecover (stock this is on your throttle body IIRC, no PCV)
through the engine crankcase
out through the driver's side PCV valve
into the intake manifold (vacuum source)
90 could be different, or you just have 1 extra valve.
PCV valve on drv side cover
@WOT , the fumes travel back up the hose from pass side cover ( which is the inlet air for PCV when you have vac
at PCV valve) to the TB .
Port for that hose is in front of throttle blades so only passing air "suction" ; not true vac
as if pulled from behind the blades like the PCV valve does
At WOT when you have greatest case pressurization , engine is only being vent by tiny 3/8" line with no vac on it
Short of a dedicated pan Evac system , possibly open breathers on each cover to relieve crankcase pressure (temp seal PCV valve ) and clean the mess off the valve covers at end of race?
Valve in pass side cover not opening because no vac from TB and valve in drv side not working
because no air available from pass side.
At WOT; totally relying on the crankcase pressure to blow fumes pass spring loaded closed valves
http://www.smokinvette.com/corvettef...t=21390&page=2
