Aluminum 350 blocks
Old May 12, 2002 | 01:55 AM
GRX's Avatar
GRX
Default Aluminum 350 blocks
Any impressions on the GM aluminum block. I know someone who wants to sell one and was wondering if the forum had some opinions on it.
Old May 12, 2002 | 01:57 AM
vader86's Avatar
vader86
Default Re: Aluminum 350 blocks (GRX)
I'm glad somebody asked, i was thinkin about this yesterday while lookin at my Scoggin-Dickey catalog. They had several AL blocks inside for SBC's. Could you use one instead of a ZZ4 block? advantages?
Old May 12, 2002 | 02:31 AM
carson's Avatar
carson
Default Re: Aluminum 350 blocks (vader86)
That is one part on my wish list, lighter weight, can be repaired,and having an all aluminum engine very :cool: .
Old May 12, 2002 | 05:56 AM
nsimmons's Avatar
nsimmons
Default Re: Aluminum 350 blocks (carson)
only problem is they cost more than an entire engine
Old May 12, 2002 | 08:46 AM
Rich B.'s Avatar
Rich B.
The C5 boyz would best be qualified to answer this...
They've had the alum block since 1997...
Old May 12, 2002 | 10:06 AM
Rynda's Avatar
Rynda
No hp performance advantage, save about 100 lbs is all. Rather expensive for 100 lbs of weight savings. Yeah I want one also. These things have been around for almost forever. The sprint car guys use them almost exclusively. If you go that route, may as well get the raised deck, siamesed bore block and go for some cubes [bigtime]. :cool: :cool: :cool: :cheers:
BBA's Avatar
BBA
Default Re: Aluminum 350 blocks (Rich B.)
I thought the C5 was an entirely different animal than the 'old school' 350???
Old May 12, 2002 | 10:29 AM
vader86's Avatar
vader86
Default Re: Aluminum 350 blocks (BBA)
right, the LS1/6 is a totally different animal than the 350 block we'd buy
Old May 12, 2002 | 11:04 AM
Rich B.'s Avatar
Rich B.
GRX posted "GM aluminum block"...
...Not a whole lot of choices, given that... :chevy
Old May 12, 2002 | 09:28 PM
GRX's Avatar
GRX
ttt
Old May 12, 2002 | 11:47 PM
Wide_One's Avatar
Wide_One
If this is the block you're talking about it is a very good start to building a great engine .....it was the one I was considering before getting involved in the LT5. You have a wide range of reasonable head setups off setting some of the price and certainly the weight savings is worth it and this block has lots of potential.
P/N 10185075
The aluminum V8 bare block weighs 90 lbs. and is cast from prime ingot A-356 aluminum with heat treatment to T6 specifications. Wall thicknesses have been increased for greater stress capabilities. The main bearing diameter is 2.45". Its rigid deck surfaces are .620". It has blind-tapped head bolt holes to improve head gasket sealing. The cylinder sleeves are semi-finished at 3.986" and will finish at 4.160" bore diameter. It has a 4-bolt main bearing cap on all five locations of 8620 steel which will clear standard oil pans. The rear main bearing is the 2-piece, pre-1986 design. These blocks are wet sump designed but can be converted to dry sump oiling by simply plugging the oil pump hole in its rear main bearing cap. Use cam bering kit P/N 12370843.
Old May 13, 2002 | 12:16 AM
BBA's Avatar
BBA
Default Re: Aluminum 350 blocks (Wide_One)
that about sums it up
Old May 13, 2002 | 02:40 PM
GRX's Avatar
GRX
4.160" bore diameter? Must be to compensate for the expansion of the AL?
Old May 13, 2002 | 04:34 PM
Jim85IROC's Avatar
Jim85IROC
No... it's to compensate for the oversized pistons that you can stuff in there for bigger cubic inches. The bores have steel sleves and operate like any old small block.
Old May 13, 2002 | 04:41 PM
Wide_One's Avatar
Wide_One
:confused: Nothing to do with expansion.....if it did the casting would be useless, the cylinder sleeves are iron and left to the engine builders spec. for honing etc.
To Aluminum 350 blocks
