Remove Standard AC Control on a 95
Old Jan 21, 2012 | 12:50 PM
LTxDave's Avatar
LTxDave
Default Remove Standard AC Control on a 95
Removing the dash to complete some...modifications. I have both electrical connectors out, but can't see how the cable is attached to the AC controller. The FSM just says to remove the electrical connectors and rotate the unit to remove the cable. Well I don't see a clip or anything holding the cable housing to the unit. It won't pull out too far, so I hope someone can give me a good description before I break some plastic. Thanks!
Old Jan 22, 2012 | 02:20 PM
LTxDave's Avatar
LTxDave
If anyone needs this info in the future, you can remove the handle on the slider, the top two screws on the passenger side and one about 3/4 over to the driver's side on the top and then remove the assembly holding the slider and cable from the AC control.
