No spark? Confused
Old Jan 22, 2012 | 07:56 PM
Bmarcum's Avatar
Bmarcum
Default No spark? Confused
This one is confusing me. There is a 89 that I working on. No spark condition. Here is what we have discovered.
Info
1. Had the ignition module tested at a local part house and passed.
2. Check the pickup coil and it did not have a short to ground. It also had a consistent reading across the pickup coil. Believe it to be good.
3. Tested the ignition coil. It did not have a short to ground and the reading across the battery to tach was in spec. Believe it to be good
Questions
1. The car has a very old battery that I will be replacing. I have it on a booster and it has 13 volt at the battery lead to the distributor. When I crank the car it drops to 10 volts. Could this be so low that it does not have a good reference signal?
2. Cap test. What should the resistance from the distributor tower/ point to the primary side of the coil be?
3. If that battery/ voltage doesn't fix it what else should I check?
Old Jan 22, 2012 | 08:03 PM
oldalaskaman's Avatar
oldalaskaman
make sure you have the 12v wire on the right terminal of the dist? and make sure it shows 12v with the key on
Old Jan 22, 2012 | 08:13 PM
Bmarcum's Avatar
Bmarcum
Default Voltage
I did it was 13 key on and dropped to 10 volts cranking. It was cranking good so I didn't even think about it being to low. It was connected to the battery location not the tach location.
Old Jan 22, 2012 | 08:20 PM
oldalaskaman
should start down to 9.5 volts, there's something called a terminal board , a plug that your module plugs into , make sure the insulation isnt rubbed off and that you're not grounding out to the dist. housing.
Old Jan 22, 2012 | 09:05 PM
Bmarcum's Avatar
Bmarcum
Default Thoughts HEI expert?
Not sure what else it could be? I also confirmed the rotor is turning.
Old Jan 24, 2012 | 09:13 AM
86Pacecar's Avatar
86Pacecar
Had the same problem in a friends 89. Coil passed tests with a meter but spark was VERY weak. Put a new coil in and it fired right up.
To No spark? Confused
