Removing negative cable from battery
Old May 12, 2002 | 11:51 AM
Kizmo's Avatar
Kizmo
Default Removing negative cable from battery
Hello everybody!
When I remove the negative cable from the battery, will I have any start up problems in terms of having to reset anything? I know that with some cars certian things have to be reset and and also activates anti-theft systems with the stereo. Or is this just the case when both pos and neg are removed?
Thanks alot. :)
Old May 12, 2002 | 11:56 AM
Rob90's Avatar
Rob90
Default Re: Removing negative cable from battery (Kizmo)
Should have no probs. Just have to reset your radio :D
Old May 12, 2002 | 12:01 PM
Kizmo's Avatar
Kizmo
Default Re: Removing negative cable from battery (Rob90)
How do you reset the radio? It's a 95 with the Bose gold stereo.
Thanks.
[Modified by Kizmo, 4:02 PM 5/12/2002]
Old May 12, 2002 | 12:27 PM
Hole-Shot's Avatar
Hole-Shot
Check the owner's manuel for instructions.
:cheers:
Old May 12, 2002 | 01:37 PM
STL94LT1's Avatar
STL94LT1
Select station, press the set button, and select the preset button. To set the time I believe you turn the radio off, press the set button, and use you up and down button to set ( hours on right, minutes on left).
Old May 12, 2002 | 05:39 PM
Kizmo's Avatar
Kizmo
Default Re: Removing negative cable from battery (STL94LT1)
OK so I am understanding that removing the neg cable will not shut anything down, right? Just re-set the radio. :confused:
Old May 12, 2002 | 06:15 PM
Rob90's Avatar
Rob90
Just the radio nothing else.
Old May 13, 2002 | 08:41 AM
Kizmo's Avatar
Kizmo
Thanks for the help. :seeya
Old May 13, 2002 | 08:44 AM
BBA's Avatar
BBA
After I removed my battery/cables, my car goes through a learning period where it runs like crap for the first day os two afterwards, then it starts running better.
Old May 13, 2002 | 09:23 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: Removing negative cable from battery (BBA)
Yup, mine ran slightly less than perfect for about a day. Then, bam! :cheers: That's what I did on Saturday... tore down the side panel, took out the battery, replaced MAF power and MAF burnoff relays, cleaned and rewrapped the connecting terminals, cleaned a couple ground connections, and replaced a couple vacuum hoses. :cool:
To Removing negative cable from battery
