considering CFI to TPI
Old Jan 23, 2012 | 11:09 PM
blackc4xfire's Avatar
blackc4xfire
Default considering CFI to TPI
after spending the past few days (literally) reading for hours and hours. I think i've decided on converting my crossfire '84 to TPI. Most of the parts I can get for next to nothing. (my buddy changed his trans am to carb, i'd be getting his stock stuff).
My understanding is that I use the TPI intake manifold, throttle body, all sensors, find a TPI ecu and wire harness? Am I missing anything. I know the power increase wont be huge, but I'm looking for a better "base" to start from. Possible future boost plans.
Also, I've been throwing the idea of converting to a carb but I really dont like the idea of going backwards technology wise. I'm very open to opinions.
Any incite would be appreciated, thanks
Old Jan 23, 2012 | 11:31 PM
qws's Avatar
qws
Don't waste your money for a lousy 30hp when you can just port your existing intake and get that.
Now if you want to do something thats worthwhile and inexpensive to do it such as a hsr,superam or miniram lets talk.
Old Jan 23, 2012 | 11:46 PM
qws's Avatar
qws
Took me a few min's to find this. You will definetly want to read this thread. It will save you hours of changing your harness out. This thread is mine ....CFI to HSR
http://forums.corvetteforum.com/c4-t...fi-to-hsr.html
Old Jan 24, 2012 | 10:28 AM
THE 383 admiral's Avatar
THE 383 admiral
As above, forget you ever thought about a TPI conversion.
Why not pick up a holley projection system... Especially one from a project that ran out of funds
Or similar..
Old Jan 24, 2012 | 10:31 AM
blackc4xfire
now im intrigued. How is the driveability of this setup? Also what kind of gains did you get ( or would i get with a stock longblock). One more question, what could I pick up that manifold + throttle body for.
Old Jan 24, 2012 | 10:35 AM
cv67's Avatar
cv67
St. Jude Donor '05
HSR gains would be huge, night and day over both the TPI and CFI.
Worth it.
Old Jan 24, 2012 | 10:54 AM
THE 383 admiral
But the HSR is butcherd due to the Low hood clearance
And making the vette specific HSR a rip off
If you install a scoop or hood get the traditional HSR
Old Jan 24, 2012 | 11:11 AM
qws's Avatar
qws
My HSR is full height since I have a scoop.
Now... the key to your conversion is the ECM. By using EBL/Flash/Ham/Multiport upgrade it will allow you to plug in to your existing ecm location. Then relocate 1 wire at the ecm plug location. Go to the engine bay spend about 20 min's make a few minor changes and your done. No need to run any new wires,harness, tear out and reinstall. You'd be using your existing harness to do this. You will also now have the ability to completely tune your car with a laptop. No prom burning...its a flash system. The best thing is it won't looked all hacked up.
The only things you want off his setup is the TB,sensors,Injectors. You will want his injectors plugs and IAC plug. Thats it.
Now put on any intake you want. Find a used HSR,Miniram,or Superam.
Search me at youtube.. slrvette ...tons of videos of driving the car
Gains...well on my stock bottom 350 it has a lot of spirit, but I also was camed,geared and had dual exhaust. Best mod you'll ever do is the ecm change...
Old Jan 24, 2012 | 11:24 AM
THE 383 admiral
QWS... my HSR is full height to... and we will both have A huge gain. over the cut and welded vette version
but other onlookers. will have sticker shock. when they see the vette specific HSR
Old Jan 24, 2012 | 11:25 AM
qws's Avatar
qws
Agreed, but mine was free from Holley..
Old Jan 24, 2012 | 11:34 AM
THE 383 admiral
Well share your holley/weiand conection... Lol sure rub it in... will still talk to you
Old Jan 24, 2012 | 11:43 AM
383vett's Avatar
383vett
QWS, that's a clean setup. I'm putting in my freshened up 406 for a race this weekend and my engine compartment doesn't look nearly as good. Willie
Old Jan 24, 2012 | 12:06 PM
LD85's Avatar
LD85
BTW, I like QWS' better than mine!
And, this fall, mine might be for sale.
Old Jan 24, 2012 | 01:05 PM
mtnmanut's Avatar
mtnmanut
Question for the pros,i was once told by a local vett shop that the injection set -up from a 85 is basically a direct bolt on for the cfi. you can get away with the 84 ecm or 85. is this so and how much of a gain would smeone expect. i like our cfi but reading your thread just got me thinking about what they told me.
Old Jan 24, 2012 | 01:15 PM
qws's Avatar
qws
Good luck in doing that.
84 is a MAP car
85 is a MAF car
What they told you is BS..an a vette shop told you that.
Old Jan 24, 2012 | 04:24 PM
Rohn's Avatar
Rohn
If you want to ditch the CF induction there is another option.
1. single plane manifold. Weiand low profile, pro products, or the one I see on EBay(Pro 1 or something) cheap. rails FP reg and lines to stock fuel hardline
2. adapter neck to a LS TB see Summit.
3. reconditioned injectors(FIC)
4. EBL with Ham board(see DCS) to mate to your stock harness. Or stock GM ECM with Ham Board.
5. A TPI pump
6. Spectre induction tube to a cone filter placed in a decent spot or right on LS TB..
Old Jan 24, 2012 | 05:23 PM
mtnmanut's Avatar
mtnmanut
84 is a MAP car
85 is a MAF car
since i read your response this am ,i tried calling this shop to verify,what or how. after several tries i made other calls and found out that they are out of business. wonder why. i'm no injection expert,so thanks for your info. by the way whats the diff. betweeen MAP and MAF in a thousand words or less.lol
To considering CFI to TPI
Old Jan 24, 2012 | 05:28 PM
blackc4xfire
map= manifold absolute pressure (sensor on intake manifold)
maf= mass airflow sensor (located before throttle body).
Rohn's Avatar
Rohn
MAP is manifold absolute pressure or manifold vacuum. Same. Uses a pressure/vac sensor. Helps calibrate fuel needed. Less Vac more fuel in general.
MAF is mass air flow. A sensor after the throttle body. Has a heated wire to montor air flow. More air sensed more fuel flows.
Old Jan 24, 2012 | 05:36 PM
blackc4xfire
maf after the throttle body? think you may have mistyped that. Unless there are throttle bodies on intake tubes that I don't know of????
