Need Help on '95 with LT1
Old Jan 26, 2012 | 12:28 AM
klfvette8903's Avatar
klfvette8903
4th Gear
Default Need Help on '95 with LT1
I have been working on a '95 with LT1 engine. Had to replace ecm and also the ccm. The car started and ran with old ecm but not the new ecm. reinstalled with new(used) ecm and programmed ecm with tech2 scan tool now car will not start. No DTC's set or stored but the security light flashes. Used vats interrogator and tech2 scan tool and ALL vats values are good but car still will not start. Reinstalled old ecm that car was started and ran on but car still will not start. Any help or suggestions would be very welcome. Thanks!
Old Jan 26, 2012 | 06:57 PM
corvette Stu's Avatar
corvette Stu
Did you disconnect the battery while taking it out and installing ?
Old Jan 27, 2012 | 01:57 AM
vetteoz's Avatar
vetteoz
Won't crank over or won't fire up?
Old Jan 27, 2012 | 06:20 PM
blue94's Avatar
blue94
This is just a guess but the vats looks for a certain resistance from the key, were the new system set to the same value.
Old Feb 1, 2012 | 01:38 PM
klfvette8903
4th Gear
battery was disconnected during ecm swap. It cranked and fired but after ecm swap it does not crank or fire. I will check to make sure the new ecm "sees" the same vats value as the old ecm. If that does not work I will post and look for more help. I work at a dealership and have all the tools needed but just can't figure out what is going on with this car?????
Old Feb 1, 2012 | 02:23 PM
1963SS's Avatar
1963SS
I'm fairly certain that the VATS resistance values are stored in the CCM and not the ECM. If you changed ECM's that would not have helped the VATS issue. Could you try the old CCM and see whassup.
Since you work at a dealership I'll assume that you've done the Start/Key On three times to allow the new CCM to retreive values from the original ECM and let the resistance values sync up.
Check your literature for the programming sequence for the new/newer BCM. Although the resistance code is stored in the BCM it is also in the ECM. The learn/program function will allow it to work. Good luck. It's kinda hard to explain but it's really simple. I've got the procedure stored somewhere if you can't find it. Just let me know.
To Need Help on '95 with LT1
