Tach
Old Jan 26, 2012 | 02:33 PM
livetohunt54's Avatar
livetohunt54
Default Tach
I replaced the cluster in my 1984 coupe,but the tach doesnt work,any idea's what to check,it worked before, thanks
Old Jan 26, 2012 | 02:44 PM
mtnmanut's Avatar
mtnmanut
You replaced it? with a replacement or you took out the original and put the original back in.
Old Jan 26, 2012 | 07:35 PM
1986coupe's Avatar
1986coupe
Did you do anything under the hood...specifically with the tach wire on the distributor?
Did you reconnect everything behind the dash the way it came off?
Old Jan 26, 2012 | 08:09 PM
DBo's Avatar
DBo
I had the same problem when I replaced my cluster on my 84. It was the tach filter (out of the distributor) that was bad. Found it at Eckler's or MidAmerica, don't recall which, for about $30.00. Dave
To Tach
