Engine management system....
Old May 13, 2002 | 12:37 AM
OrangeC4's Avatar
OrangeC4
Default Engine management system....
I think that is what it is called. It is a program that you can load onto a laptop computer, and monitor what is going on with you car in real time. I have seen them for other cars, but can't find one for a vette.
Old May 13, 2002 | 12:41 AM
Raistlin's Avatar
Raistlin
Default Re: Engine management system.... (OrangeC4)
the faq in the c4 ecm/prom section has a good description of a few programs that will monitor the cars computer.
i have used datamaster.
Old May 13, 2002 | 01:06 AM
OrangeC4's Avatar
OrangeC4
Default Re: Engine management system.... (Raistlin)
Thanks I will check it out. :cheers:
Old May 13, 2002 | 03:53 AM
BlackRocket's Avatar
BlackRocket
You may consider going with a Speed-pro. I've heard nothing but rave reviews about them. Lots of $$$ though! :eek:
Old May 13, 2002 | 04:11 AM
nsimmons's Avatar
nsimmons
Default Re: Engine management system.... (BlackRocket)
if you wanna change things in real time, you'll need a new computer, something like a haltech
if you just want to monitor the ecm check this out http://winaldl.webhop.net
it'll work on your 85, its free the the cable only costs a couple bucks to make.
[Modified by nsimmons, 12:14 AM 5/13/2002]
Old May 16, 2002 | 02:00 AM
OrangeC4's Avatar
OrangeC4
Default Re: Engine management system.... (nsimmons)
:cheers: Forgot I made this post. I might try this one out, I will let you all know how it works.
To Engine management system....
