Check Engine light 1996 LT1
Old Jan 31, 2012 | 03:06 PM
needhamboy's Avatar
needhamboy
Default Check Engine light 1996 LT1
I purchased my 1996 limited edition convertible in October 2011 and it ran great. The check engine light just came on so I took it to Advanced Auto Parts for a free diagnostic check.
It showed codes:
P0138 (Oxygen sensor circuit high voltage) Bank 1, sensor 2
P0140 (Oxygen sensor circuit no activity detected) Bank 1, sensor 2
P0171 Bank 1, system too lean
P0174 Bank 2, system too lean
P1371 Mfg code
Can anyone tell me what this means?
Old Jan 31, 2012 | 04:30 PM
96GS#007's Avatar
96GS#007
It showed codes:
P1371 Mfg code
It means the aft o2 sensor on the drivers side is bad, or the wiring to that sensor is bad, or the cat on that side is bad. 9 times out of 10 it's just the sensor.
Old Jan 31, 2012 | 06:12 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Replace B1S2, clear the codes and see if any come back.
Old Feb 2, 2012 | 10:11 AM
needhamboy's Avatar
needhamboy
Thanks, will do and advise.
To Check Engine light 1996 LT1
