horsepower question
May 13, 2002 | 07:34 PM
horsepower question
coil and electric fan or a 52 58mm throttle body does this help in hp department :rolleyes:
[Modified by skills68, 6:34 PM 5/13/2002]
[Modified by skills68, 6:43 PM 5/13/2002]
May 13, 2002 | 08:15 PM
Re: horsepower question (skills68)
Not clear on your question, what motor are you referring to?
In general coils do not make hp, they insure proper ignition. An electric fan can provide more hp over a mechanical fan and also keep coolant temps lower. A larger TB will make more power over 48mm with a motor that requires more breathing such as a heads/cam or stroker application.
:cheers:
May 13, 2002 | 08:17 PM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:rolleyes: NO :rolleyes:
May 13, 2002 | 08:21 PM
Re: horsepower question (mackeyred96)
mackeyred96 were u at englishtown sat night by ur times u must know something help me out :seeya
May 13, 2002 | 08:26 PM
No, I wasn't at E-town this week but I be glade to help.
May 13, 2002 | 08:45 PM
a 52mm TB might help, if you were more descriptive about your motor, a 58mm is worthless in my opinion.
electric fan might give some hp, but just a couple
an ignition upgrade is really only necessary for high rpm motors, but it couldnt hurt. Wont give any hp until you get real high rpm tho
May 13, 2002 | 08:48 PM
Re: horsepower question (vader86)
u only have 2 win by a couple thanks :cheers:
