1989 dash issue
Old Feb 12, 2012 | 12:01 AM
camario's Avatar
camario
Default 1989 dash issue
i was driving yesterday and my tach gauge light started fading, but comes back at times. all other parts of gauge are lit up fine. would this be a short in the wireing or could the cluster be dying?
Old Feb 12, 2012 | 12:05 AM
1986coupe's Avatar
1986coupe
The cluster isn't as complex as some make it out to be. Could simply be a loose wire...check the one on the distributor because it could be the source.
If it is a loose wire behind the cluster then you will have to take it out to see if there are bad connections and fix them.
Old Feb 12, 2012 | 12:12 AM
camario's Avatar
camario
ok so there is a wire going to distrib? will check that out in the morning ty
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
The bulbs are plugged into the sockets that twist into a circuit board. On those sockets, you'll find two small mildly springy tabs. Those tabs put pressure on the eched (solder) trails of the circuit board. That's how they get there power supply.
Over time, the solder oxidizes. A casualty will be the dash light connections to the circuit board.
Good news it's eash to fix after pulling the cluster. Bads news, that's kindof PITA.
When you get it out, clean off the oxidation, rotate the sockets in/out of their holes a time/two. That will restore proper connection and cure your problem.
Old Feb 12, 2012 | 12:23 AM
camario's Avatar
camario
awesome thanks for the responses
To 1989 dash issue
