C4 interior bulb info
Old Feb 12, 2012 | 03:23 AM
x01660's Avatar
x01660
Default C4 interior bulb info
I am wanting to change over all of my interior lights to UV (Black light) LED's. All of them except for the map light. I went to superbrightleds.com and saw that there are several options for some of the bulb locations, so if anyone could give me definitively what bulbs are in the car (or can point me in the right direction or thread) that would be awesome. Car is a 92 targa top. Thanks!
x01660
Old Feb 12, 2012 | 03:25 AM
LouisvilleLT4's Avatar
LouisvilleLT4
Not sure about where to get a bulb listing, but that idea sounds freaking sexy.
Old Feb 12, 2012 | 03:34 AM
x01660's Avatar
x01660
Yes, it will be!!! Here are some pics of the car (haven't got it yet, but the guy is holding it for me)
That with the UV's at night is gonna be really hot...
And his name will be Poseidon!!
I'm so excited!!
x01660
Old Feb 12, 2012 | 05:50 AM
armybyrd's Avatar
armybyrd
Sounds neat! Be sure to post pics after its all done
Old Feb 12, 2012 | 07:18 PM
x01660's Avatar
x01660
Bump. Anyone know what bulbs are used in the interior?
x01660
Old Feb 12, 2012 | 10:34 PM
MarkBychowski's Avatar
MarkBychowski
corvettehid sells led interior kits for C4's. He may have them in UV or would at least know the bulb types.
Old Feb 12, 2012 | 11:10 PM
x01660's Avatar
x01660
I'm not gonna lie; they are kind of pricey... I can get my bulbs from the site I posted for 30 bucks vs 90... I'm a college student and on a budget, so every penny helps...
x01660
Old Feb 13, 2012 | 01:50 AM
Cliff Harris's Avatar
Cliff Harris
I think they changed lamps by '92, but my '86 shop manual has a list of all the lamps in the car. Check your FSM -- you DO have one, don't you?
Old Feb 13, 2012 | 01:18 PM
FrankieD's Avatar
FrankieD
these are taken from my 1993 owners manual, so the 1992 should be the same:
Glove Box.................................... 194
Air Conditioning/Heat Control........... 37
Auto Transmission Indicator............ 194NA
Console Compartment.................... 564
Courtesy Light Cargo..................... 906
Flood-Door................................... 73
Courtesy-Door.............................. 212-2
Courtesy-Floor.............................. 562
Courtesy-Rear(Convertible)............. 562
Underhood............................... .... 211-2
Mirror-reading Lights..................... 168
Mirror-Console Flood..................... 74
Visor Vanity Mirrors....................... 74
Old Apr 10, 2013 | 10:22 PM
blownrunner's Avatar
blownrunner
So I am at this Corvette graveyard North of Tampa and saw a few vettes with dashboard fires, and it got me thinking... The passenger footwell light is in very close to wiring for computers, stereo, and doors right below where the radio control box is. The top of the light housing bulb is exposed to these wires and I bet this is where a few of those dashboard fires started. I disconnected the footwell lights until I get LED bulbs which run much cooler.
Old Apr 11, 2013 | 12:52 AM
vetset84's Avatar
vetset84
I replaced most of my interior lights with leds, what i did was measure the light housing with a pair of calipers and put as much as i could in them. refurbished the housings and sprayed them bright gloss white. most bulbs have either a t10 base or a 10 mm festoon. do a ebay search for leds and you will find a lot most come with both type of bases. it has been a while but its something like 36 led square for the hush panels and 40 something for the rears. i counted one time and i have over 300 in total. don't do the cluster with leds though, tried that and didn't work out. soderd my engine bay lights because the housing was melted. It has been 2 and a half years and the cheap ebay lights still work. used a 4 led super bright waterproof bulbs for the engine bay and spare tire carrier. next is the running lights to led but need some quality types for that.
Old Sep 26, 2013 | 02:22 PM
2VettesMike's Avatar
2VettesMike
Saw heat damage in the same area when I had that part of the dash out recently replacing a heater core. You can drop the hush panel and ziptie the wires up further and that would help. My guess is the heat damage was caused by the interior lights being on for a long period of time like door open, cleaning interior, etc.
Mike
To C4 interior bulb info
