Water Pump bolt sealant
Old May 14, 2002 | 12:08 AM
Tom73's Avatar
Tom73
Default Water Pump bolt sealant
I am changing out the water pump on my 90 L98. What sealant should I use on the bolts that run into the water jacket? Also is sealant needed on the pipe fitting where the heater hose pipe screws into the pump?
Also, any thoughts from the C4 crowd on the use of Water Wetter?
tom...
Old May 14, 2002 | 12:38 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Water Pump bolt sealant (Tom73)
I used Permatex gasket sealer on the bolts and on the fitting threads.
I use Water Wetter, couldn't hurt.
Old May 14, 2002 | 11:18 AM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Any teflon based sealant will do...most auto parts stores carry the liquid version (actually more like a paste)
To Water Pump bolt sealant
