blinkers
Feb 12, 2012 | 06:30 PM
blinkers
1985 c4 corvette.
when i turn my left turn signal on, it turns on but dose not flash on and off. usually i can hear a clicking from the dash, but dont hear it. when i turn the right on i hear the clicking.
Feb 12, 2012 | 07:55 PM
A burned out bulb or bad connection will do this.
This happened once on my '87 and I tracked the problem down to the right front light. I pulled the bulb & the filament was fine. I put it back in and all was well---just pulling & reconnecting it improved the connection enough for it to work.
Feb 12, 2012 | 08:18 PM
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Quote:
Originally Posted by
3D87C4
One of the left turn signal bulbs is probably burned out.
They are dual filament bulbs, so you'll still have parking lights.
If the bulb is burned out, the turn signal flasher (what you hear clicking) won't work.
Also, this isn't anything specific to Corvettes.
Every GM car I've ever owned worked this way.
Feb 13, 2012 | 02:02 AM
Try the 4-way flasher mode and see how that works.
Feb 22, 2012 | 08:28 PM
how would i go about checking the rear lights? i dont wanna mess anything up because at the moment i dont have a job
Feb 22, 2012 | 08:35 PM
Cliff Harris
Tried this yet? This uses a different flasher than the turn signals & may help identify the bad bulb (if that's the problem).
Feb 22, 2012 | 09:33 PM
spartanc4vette
Turn the ignition on, push the signal lever down, walk behind the car and see if the rear light is on. If not, change the bulb and get a job.
Feb 22, 2012 | 10:12 PM
My 85 is doing the same thing. I thought I was going to have to replace the flasher but I will check all bulbs first with the four ways. That was something I had not considered.
Feb 23, 2012 | 07:13 PM
383vett
get a job.
im trying my best
(( small town not many jobs
Feb 23, 2012 | 07:34 PM
found the problem, left outer tail light. its burned out. next question is how do i go about replacing it?
Feb 23, 2012 | 07:50 PM
Feb 23, 2012 | 08:16 PM
spartanc4vette
im trying my best
On, the record, I wasn't being a smart ***. Just my attempt at humor.
Remove the two phillips screws on the side of the outside lens, remove the lens and change the bulb. Then move to another town and get a job.
Feb 23, 2012 | 08:23 PM
Oh, now that sounds a lot easier...
the bulb part, I mean.
Feb 23, 2012 | 10:48 PM
383vett
lol XD
Feb 23, 2012 | 11:02 PM
383vett
On, Remove the two phillips screws on the side of the outside lens, remove the lens and change the bulb.
no such screws
Feb 24, 2012 | 08:45 AM
Feb 24, 2012 | 10:30 AM
spartanc4vette
no such screws
My bad. My original lights are up in the attic with my brain. My newer lights have screws.
Feb 24, 2012 | 08:11 PM
got her done, my brother was able to put his arm in from the bottom and get out and and put back in. problem fixed
D
Feb 25, 2012 | 10:48 AM
Feb 25, 2012 | 06:42 PM
HlhnEast
lololol
