94 cold starting problem
Old Feb 12, 2012 | 07:10 PM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Default 94 cold starting problem
A friend of mine has a 94 that has a hard time running cold. He has to run it for 5 minutes or it stalls. Anyone had this problem? I am not familliar with the LT1 setup. IAT? Coolant temp sensor? It all looks ok on the scanner.
Old Feb 12, 2012 | 10:42 PM
VetteMed's Avatar
VetteMed
an engine that doesn't run well cold, but runs well when warm, may have a vacuum leak. some vacuum leaks will be reduced as the metal parts heat up and expand.
