losing fuel pressure
Old Feb 12, 2012 | 07:35 PM
Handi's Avatar
Handi
Default losing fuel pressure
I have a 1994 Corvette LT1...I was driving the other day and out of the blue the car died... waited about 1-2 minutes and it started right up. This has happened several times so I put a fuel pressure gauge on so I could see it in the window. I have 42-44 psi with key on and after start between 34-38 psi. So I assume the fuel pressure regulator is lowering the pressure. The car drives fine for between 5-10 minutes and will lose fuel pressure. You can always count on it restarting after the 1-2 minutes. I have changed fuel pump and strainer and the fuel filter. I have changed the oil pressure sensor even tho the gauge says I have pressure. I have run the car with and without the fuel cap...no change.
My question is what's causing the loss of pressure and what's with the wait time to restart?
Old Feb 12, 2012 | 08:51 PM
vetteoz's Avatar
vetteoz
To what pressure?
Zero as in pump not working?
Old Feb 13, 2012 | 09:41 AM
Handi's Avatar
Handi
Yes as in ZERO pressure....I can watch the pressure gauge that I have installed and when the car dies the gauge psi drops to zero....wait between 1-2 minutes and I get my 42-44 psi back with the key on...then starts like there was never a problem....but the cycle continues....Something is shutting the pump off...and the only thing left that hasnt been changed is the pump relay....but then why is there the time delay for the pump to come back online??
Old Feb 13, 2012 | 01:51 PM
GKK's Avatar
GKK
Any Codes stored?
Old Feb 13, 2012 | 06:42 PM
93Rubie's Avatar
93Rubie
Electrical. I'd swap out your fuel pump relay and check your fuses. Look for any signs of corrosion. Clean and check the grounds too.
Old Feb 13, 2012 | 07:08 PM
c4cruiser's Avatar
c4cruiser
Replace the fuel pump relay and check the condition of the harness connectors at the F/P especially where the wires attach to the connectors. Loose wire/connector or bad relay.
Old Feb 13, 2012 | 10:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Did you check for corrosion on the two contacts where the FP connects electrically to the holder? If blackened they may be the problem and cleaning them may eliminate the issue.
Old Feb 19, 2012 | 02:28 PM
Handi's Avatar
Handi
Default fuel pump relay
Bought a new fuel pump relay...fsm says its located under the pass side dash but I cant find it...anyone know its location?
Old Feb 19, 2012 | 02:39 PM
SouthernSon's Avatar
SouthernSon
I have to wonder if maybe a stuck injector may cause this, too? Not sure what else a bad injector may cause, though. Without starting engine, the pump will run a couple of seconds and shut off. Does the pressure gauge maintain? If not, regulator needs rebuilt or replaced but may not be the whole problem.
Old Feb 19, 2012 | 05:52 PM
93Rubie's Avatar
93Rubie
Your probably going to have to remove the lower carpeted panel to access it. It is there. Page thru the FSM some more.
Old Feb 19, 2012 | 07:27 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Probably not a answer to your problem but on my 88 the wire through the gas tank cover had an intermittent break.
Old Feb 20, 2012 | 09:52 AM
Handi's Avatar
Handi
Default It's fixed !!
My problem just returned. CFI-EFI clued me on how the fuel system actually works...THX. I want to replace the fuel pump relay but the manual says it is under the passenger side dash. The only relays I find are in a cluster inside a box that do not resemble the fsm picture and are not marked. Anyone know if this is the right location and which particular relay is for the fuel pump?
Old Apr 3, 2012 | 06:46 PM
Handi's Avatar
Handi
Default Location for the fuel pump relay?
Still looking for the location. Thx
Old Apr 3, 2012 | 07:16 PM
383vett's Avatar
383vett
The earlier years had the relay on the firewall on the passenger side. Not sure about your year though.
To losing fuel pressure
